supersticky
1,012
46
taunton somerset
I'm cheap
I can't afford a thing
I want second hand dirty n used
Near side driveshaft.
Could anyone tell me what other pissing cars will fit mine. Pd150 stage 9 jet powered rocket bleeding ship.
Thanks all.
Sent from my M2007J20CG using Tapatalk
I'm cheap
Thanks all.
Jr cv joints do complete shafts for about £30 mate
Reactions: Manic172
Aye and they are only worth £30, wouldn’t put one on my wheelbarrow
i had 4 off them and they were all scrap, went back to OEM
1 and 2 had split boots from new
No.3 vibrated its nuts off
No.4 got put straight into the skip (didn’t even open the box, and didn’t want to sell on ebay because i would get negative feedback about how rubbish it was)
I put two on my Leon and have had no problems with them at all
Thanks for the information guys much appreciated, looking for used OEM just trying to find out what other vag group cars will fit mine (wider used choice)
Could anyone tell me what size spline bit I need for the driveshaft also the hub nut.
Cheers lovely people
Hub nut is 30mm 12 point socket. Spline m8 if I remember. I bought a pack from draper saved my ass many times hold on I’ll link it
Well worth every penny
A dedicated member @ 08:00 Sunday morning Bloody top man, cheer mate.
It’s the job, used to getting up at **** o clock haha. No worries honestly they’re piss to change. Make sure you’ve pt a breaker bar to shift that hub nut
Nice one pal yeah got a 30" breaker ready, what sort of job time is this.
I've heard you'll need to knock the hub shaft out.
Spline set bought again thanks.
No problem. Erm if your taking your time an hour per side. Jack it up, axle stands under chassis rails, wheel off. Wedge a screw driver in the brake caliper/disk to stop it moving. Undo the little drop link thing so you can move the suspension leg in and out. I undid gearbox side first then hammered it through the hub although one side slid out by itself. The time is in getting the old one out the hub.
As soon as that hub nut is off, soak the hub joint in penetrating oil then undo the gearbox side
