Seat Leon 2007 rear Ticklight retrofit
Feb 26, 2021
14
Anyone can that advise me i would appreciate it i got these tick light fitted i had to change the full bootlid etc however the main back light aint working neither is the wiper, does anyone know what it could be?
I do have the light sensor on my dash but they have new bulbs in
my car is on a 2007 plate im not sure if that makes a difference
Feb 26, 2021
14
Please see image below as the inner tick lights not switched on
Rusty2k
710
133
It's probably the tailgate shut sensor. The car thinks the tailgate is open so has shut off the electrics.
The sensor is built into the latch mechanism but check the wiring inside the tailgate in the first instance.
Feb 26, 2021
14
Thanks buddy i will get the wiring check however do you know anything why the lights aint working...
Rusty2k
710
133
Check the closed signal from the tailgate latch. If the car thinks the tailgate is open it turns the lights off.
Feb 26, 2021
14
But then on my dash it would say my tailgate is open which it doesn’t say that which is strange
Rusty2k
710
133
It's switched to negative when open so a broken wire or faulty switch wouldn't make the contact. It was the fact that the wiper is also not working that makes me think it might be this.
Is there enough cable on the rear light wiring to give enough room to plug your old lights in to test?
Reactions: 300bhpdaily
Feb 26, 2021
14
Yes i tried testing my old lights wouldn’t work
andylong
489
I think the switch is on the latch for the tailgate open or closed.
If none of your new or old lights work you should check the plug to the tailgate. If you have a meter you should look for the relevant voltages on the car wiring side.
There's probably a forgotten connection or one that became unplugged or broken during the swap
andylong
489
I think you should compare the connections and Thier cables. The wiring diagrams should different wire colours for different years altho that doesn't explain why the old lights don't work, unless you kept the new loom in the tailgate.
There is a cabled earth with socket and plug coloured brown but if your fog is earthed so is your reversing light so again it points towards the plug wiring on the positive side.
andylong
489
From wiring diagrams there are cabling differences in path or colour from 2006 to 2012 and different connection to the onboard supply control unit.
I would be tempted to use the old loom in the new tailgate.
andylong
489
It's hard to know how things are actually working if you can't test the voltages, well it is for me and the wiring diagrams are terrible in the manual, covering multiple years and left/right hand drive.
You can compare the cabling path for each loom from plug to bulb for each component to identify the differences
