Mr Pig
2,928
1,104
Three of the windows work correctly.
The passenger window goes up and down fine on the button's first position but when you click the button to the second position it does not auto-open or close as the others do. I thought it might be the switch but it's the same if you use the passenger door or driver's door buttons.
Any suggestions?
Thank you.
Any suggestions?
Thank you.
It needs the anti pinch resetting. There are instructions in the manual :) Involves winding them all the way down and holding the down for 5 seconds after then doing the same back up.
Reactions: Mr Pig
I thought that would be what it was but I've tried that several times with no effect.
