Ian986
78
29
UK
Hi For you that have the hybrid Model what Regeneration setting do you use?
I have put mine in the highest mode as don't have a charger installed at moment so can only grab a charge when go to supermarket as they have free charging locally. I have done a few longer journeys and is down too low 40MPG, but does give you a bit of charge to do last part on electric only, so goes back up slightly. I wondered when on motorway if was not such a good idea to have on such a high mode as slows car down to fast would be better to coast a bit. the reason on a run my BMW Z4 30i give better fuel consumption if there is no charge in the Formentor.
How do you change the regen settings? Which menu?
I can’t remember if top of my head Mrs is away in the car at moment I will have a look at the weekend when she is back if not one pipes up
Thank you, appreciated. I have one other question you might be able to solve for me at some point too…. When you have your car plugged into a charger and charging… is there a yellow warning triangle on your dash? I’ve noticed mine does… but not sure if it’s another software bug or whether it’s supposed to be there?!
I get my vehicle tomorrow and have an outside charger so I will plug it in and let you know!.
Sent from my SM-G998B using Tapatalk
You have to swipe across until you get to the last dot on the right
Then see below
Reactions: RJP and Phil7g
