Rear Air con - how do i activate it?
Aug 28, 2021
Hi, we collected our new Leon estate yesterday and feel little stumped, when it comes to the sir conditioning. We csn turn it on for the front of the car but, cannot get the vents in the rear to activate. Can anyone help? I have looked through the manual but it may as well be written in martian. Thanks for any advice as my dealer is closed for the bank holiday.
Reactions: Leonfr140
dan555
241
95
In the air conditioning menu (press the fan icon in top middle of screen) > 'rear' on side menu
It always works with the main air conditioning all you can change is the temperature, the same as the rear panel. If no air is blowing out make sure the vents are open
martin j.
1,997
894
Fife
A dealer shut for a bank holiday!!!! One I worked in only shut Christmas Day and 1st n 2nd January, if punters are on holiday they might be out to buy a car.
BoomerBoom
777
286
That menu can also sync and lock out the temp controls in the rear but yes, like all the other vents, if you slide them all the way to one side they will shut off.
Reactions: Antera
DuckPit
85
7
I have the same issue when I tried to get rear working today but may be it's me (again). For me when I sat in back the rear control said 'off' pressing buttons did nothing, in the 'rear' sub menu in Infotainment all 'rear' options were grey'd out touching them did nothing. I got it working in the end but not sure how. Does the rear only work in manual aircon mode and not auto which would make sense? Does it actually detect if the rear vents are open and if not set it to 'Off'?
FalconTech
84
30
To "activate" rear AC please follow:
- go to rear AC menu (here you can see gray rear control buttons)
- tap on the numerical temperature value of the driver's side (on the top bar)
- tap "SYNC"
now the rear control functions should return
Dec 7, 2022
- tap "SYNC"
Thanks! Very helpful, worked for me
