Aug 10, 2022
16
Hi I have a Seat Leon FR Mk2 2.0TDI 170 CR
Can you confirm if my engine code is CFJA also I can’t seem to find a water pump or part numbers for one,
also does this model have a secondary water pump also I’m just abit confused any info or links would be appreciated
thanks I’m advance
Sorry I’m new it’s my first post ? it’s cool. You can buy the water pump from euro car parts using your reg buddy. ? have you used them before? If you buy thepart from there website there will be a discount code at the top of the page somewhere to copy and paste into checked you’ll get into 40% off it.
I went on euro car parts and put my reg in and it said about checking the fitment tab so wasn’t sure if it would fit or not, didn’t want to buy the wrong one that’s all
If the spec sticker says CFJA it probably is. I think you can double check by looking where the EGR valve is. It's bolted onto the ASV on the CEGA but IIRC on the CFJA it got moved to the back of the engine?
How much power are you looking to run? That wide belt upgrade is for those running quite alot more power.
Thanks for your help man! It’s appreciated!
man’s hopefully somewhere around 300bhp eventually
