Chillout
218
289
I've made a slight improvement on the Leon Cupra FPA dataset version LO00, so it now has a Race setting for ESC System, which shuts off the Start/Stop feature. (Without going into too much detail: this will set the start/stop in "Offroad mode", where it's never shutting the engine off).
Code:
Individual HMI shows the following settings:
Position  Control                     setting:
  0      Engine                        : Comfort Sport Eco Race
  1      Steering                      : Normal Race
  2      HVAC (Air Conditioning)       : Normal Eco
  3      DCC                           : Comfort Sport Race
  4      ACC                           : Comfort Sport Race
  5      Front Differential Lock       : Normal Race
  6      ESC System                    : Normal Race
Only use this dataset if you know what you're doing, usage is at your own risk.
Flash the dataset to 0x0B80 of your gateway (or 0x2388 if your gateway is less new).
Read more about the modification itself here: https://www.drive2.com/l/624636130226099733/
Read more about my entire Driving Profiles research and all the possibilities here: https://github.com/jilleb/MQB-FPA
If you have any other cool ideas for expanding the settings on your Cupra, let me know in this topic. Please no PM's.
Just drop your dataset here, and maybe we can come up with a dataset exchange here.
(and if you want to say thanks, feel free to buy me a coffee https://www.buymeacoffee.com/jille )
  • Leon Cupra FPA datasets.zip
datasets fits for which version of SW in Gateway ? I have 5Q0907530AM 2265 Conti ..but I see that script is for newer gateways 3Q0
and what about MKE fatigue detection? it is under Fec but Fpa is also...are you plan to investigate it and ehmactivate somehow?
No, that doesn't have my interest. I don't see the benefits of investigating it.
Indeed the newer gateways. I'm working on a template for the earlier ones.
Q1 will be they also tried on real car or only porting "code & approaches" will be performed?
Q2 can you look also on throttle response -please- ? :) according https://www.seatcupra.net/forums/resources/drive-profile-settings-guide.69/ throttle is changed among switching profiles ... (i have xperience 2015 and Coding 0x01 Engine byte0 to Audi doesnt help, neither 0x44 Steering “driving profile switchover” to "Direct, controlled over threshold"
Unfortunately, I have no extra car running the other gateways.
Good question, I'll get into that.
hi @Chillout , did you discover any relationships between bytes ? cause my throttle is very dead at the beginning and doesnt solve it tweaks on the internet (Engine code set from 01 to Audi 02 but I have 33 already, also Switcing drive profile). thx
Yes, there are a lot of relations between the settings inside the FPA and the engine behavior. For isntance, my 1.5 has Eco, Normal and Sport engine modes, as well as Normal, Eco, Sport gearbox, and they heavily influence the way the car is performing.
Reactions: mykro
Code:
Hey, thanks for the cool work. I uploaded the profile to my Cupra, the engine now retains the setting, but I don't see the ESC tab on FPA. Maybe that doesn't work for every model?
