Finally finished the project. It is an italian Supersprint stainless cat-back system, with custom quad pipes finished in copper cerakote for durability. CSR rear diffuser also got added, it's a bit more discrete than the MAXTON one. My Formentor is the 1.4 eHybrid 245 VZ.
Quick pics and video of the result, and the story and more details underneath. Enjoy!
Video and sound:
Upon receiving the exhaust, there was actually a hole in the weld, but Supersprint was really quick to fix it on their account of course. So hats off to their customer service!
The amount of work needed to get this exhaust swap done was a bit much to be honest. When removing the plastic exhaust trim you open up a gaping hole underneath the diffuser, exposing sensors and cables etc. See here:
Now, the towbar also leaves a big hole, so It's not a catastrophe. But the one here is in the spray zone from the rear tyres. So I cutout a piece of bitumen to close up the worst bit:
Gonna change that bitumen to rubber one day, as I fear winter will cause it to crack at some point.
These are the plastic T-rivets (I just made up that name) that I use to fix the bitumen cover and the rear diffuser. I highly recommend something similar if you're planning on doing any plastic bodywork:
Now, check out the size difference of the Supersprint vs stock resonator and muffler:
Almost forgot, you also need to cut the underlying plastic diffuser to fit the rear pipes. You can see that cutout (kinda) here:
All done!
I put together the rear pipes and tips myself, which was a bit of a hassle. A 1.5 radius 64mm stainless 90° bend was needed to be in the right place.
The tips are actually poking out a bit too far, so I'm gonna reposition them a bit.
An interesting thing, check out the difference in how much they poke out when warm vs cold. Pretty clear picture of thermal expansion here! Thought it was funny:
So glad this is done! It was fun, and the sound is completely different now.
Video and sound:
All done!
