Fitted steering wheel but have slight issus
Fitted flat bottom steering wheel with new canbus moduel, steering module, slip ring
Most of it works ok but, cruise control has a problem and I can not get the button with the telephone to work on steering wheel, the phone connects ok and works
Any ideas anyone
Any ideas anyone
You should have copied the settings on your old canbus before you replace it with vag.com
you now need to program the module and the cruse control
I did copy the settings of the old can bus I have coded this new one in
it did work for me, I upgraded my Leon with fr facelift steering wheel, canbus and control unit, it shows some fault lights but after clearing with vag cruise and all was working fine, just make sure the part numbers are correct ones including the slip ring, I no longer have this leon mk2 but the instructions is some where in forum
cruise control inop now
cruise control wont work after change of f\b steering wheel, canbus, steering module
this my scan
VIN: VSSZZZ1PZ7R066896 License Plate:
Mileage: 179510km-111542mi Repair Order:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ7R066896 Mileage: 179510km-111542miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 4352
Revision: --H42--- Serial number: SEZ7Z0F3668597
Coding: 0050072
Shop #: WSC 00191 264 15243
VCID: 7AFDA8F7356CC3EE30-802E
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 01324 210 01865
VCID: 73E385D31206B2A673-8026
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
Shop #: WSC 00000 000 00000
VCID: 69DFE7BB40CA7876C9-803C
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004598134
Coding: 81880F2F00041000431D00000000000000007F075C4000
Shop #: WSC 06441 785 00200
VCID: 6CD19EAF4F386D5EB2-8038
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 141206 022 0601
Coding: 00056208
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R5 AIRBAG VW8 029 2522
Revision: 11029000 Serial number: 003B0PR6E9NW
Coding: 0021045
VCID: 2F6B49A3BEAED646D7-807A
Subsystem 1 - Serial number: 6332MSME1451386F
Subsystem 2 - Serial number: 6342MSME1548485E
Subsystem 3 - Serial number: 6351HTS62ADO8M47
Subsystem 4 - Serial number: 6361HTS62AD03B17
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000734
Shop #: WSC 00000 210 01865
Subsystem 1 - Part No: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: 00000226
Shop #: WSC 00000
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 941 A
Component: KOMBIINSTRUMENT VO3 0522
Coding: 0002401
VCID: 2B535DB38AB6AA66FB-807E
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 160114F1001905
Coding: 460203
Shop #: WSC 12345 123 12345
VCID: 7BF3ADF3FA56FAE62B-802E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0522
Shop #: WSC 06402 145 00197
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000518969028
Coding: 0000688
VCID: 3B736DF37AD63AE66B-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
VCID: 35677BCB5CF2EC969D-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006050D60085F86107C00
VCID: 0303D51342A6822663-8056
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000048969023
Coding: 0000688
VCID: 3C716EEF7FD83DDE62-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0042414
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11005001 Serial number: 00000000890291
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11005001 Serial number: 00000000887019
Coding: 0000144
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2PQ5x H23 0060
Revision: 00000001 Serial number: 00000000544948
Coding: 0000422
VCID: 326D40D7AD9CFBAEB8-8066
No fault code found
Greetings from Greece.
Iam happy owner on SEAT LEON 1P1.8TSI 2008 prefacelift with MFS.
I have bought cupras facelift steering whee as shown in the photos.
I am in search for an airbag at the moment plus trying to sort out every other module to be ready for the installation process + coding.
The list of things need to be changed is the same for the cupras MFS as is with FR’s?
MFSW Airbag Harness p/n 1K0 971 584 C
MFSW Control Module p/n 1K0 953 549 CH
Collector slip ring 1K0 959 653 C
CAN-BUS 7N0907530AF
couple morequestions:
Is it possible to use existing slip ring? Is it compatible? If I tape it to prevent it to move during the swap?
where is CAN-BUS 7N0907530AF locates?
what steps I need to follow to copy in VCDS existing canbus steering wheel settings before swap the new one?I need to done it one by one manually orthere is a backup restore feature possible? I’m not vagcom expert but can do couple things.
Just doing this to my car, replaced the module and my power steering has gone heavy… light on the dash too.
Not sorted this yet. Bought the CAN-BUS MODULE going to fit it in this week. Hopefully that gets rid of the power steering.
Let me know how you get on man - I want to create a proper guide on how to do it as there is soo much mismatching and conflicting information about.
Everything has been sorted on my car. Steering wheel works without any problems. I had the power steering issue but after the angle sensor was coded correctly it works perfectly. If you need any help im more than happy to help :)
Reactions: thatslowk1
Did you have to upgrade to the CH module an all that? I have just bolted the wheel up and used it without a horn or airbag.
The airbag wiring is the same to be fair as the pfl.
Yep the module is 1K0 953 549 CH. Make sure to code the sensor at it will need calibrating, without that power steering will be heavy.
