Mar 20, 2023
My Ibiza 1.2 TSI (2015) makes a mysterious sound on engine startup, which lasts for around 20 seconds. It also does it, only amplified, when in reverse gear. Any ideas?
Thanks in anticipation.
It will be the recirculating flap motor that is part of the heater (HVAC) system.
Thank you for that pointer. Is it also known as an air con flap actuator? Doesn't sound too bad. Is it easy for a mechanic to get access to fit one of these, do you happen to know?
Yes that description also works, I can't say for certain how easy it is to get in to replace it, these cars are designed as LHD so maybe not so easy as your one is RHD, a DIYer could probably manage it easier than the directed method issued by VW Group - health and safety apply more for workshops, DIYers accept skinned knuckles and working at horrible body positions!
There is an outside possibility that the "heater" controller has lost some of its stored terms, it initially needs to find and store the end-stop voltages of all these flap motors, which it then stores for future use. What you are hearing is the physical/mechanical flap end-stops being reached then the motor being sent off to the other end-stop, ie being driven hard open and then hard closed etc etc, though normally it is dirt on the positional feedback potentiometer track or its wiper - or a broken bracket etc.
Reactions: SEATtheTABLE
