Hi All,
My 290 ST has a stage one map on it putting out around 370 BHP. The pedal is not popping back up when cold and it is difficult at times to get it to go into 2nd gear. There also the odd whiff of clutch at times. The garage I went to said that these were signs of the clutch being on it's way out so Im after some advice.
I've had a sachs organic clutch previously which was strong enough to handle stage one no issues but after 50K on it I was sick of the heavy feel of the pedal. I swapped to a Helix clutch which was much better in pedal feel but after approx 30K it appears to be giving up. I've seen on other forums talk of putting a TTRS clutch into the mk2 and also mk 3 as a better "OEM Feel" solution. Anyone on here have any experience of it?
Im based around gloucester so any recommendations on a reliable trustworthy garage to get a seconsd opinion I would be grateful too.
Thanks again,
Thanks again,
