Sep 13, 2026
Hi all,
I’ve got a 2018 SEAT Leon Cupra 300 and I’m trying to track down a front-end rattle/knock.
The main issue is a rattle/knocking noise over lots of small bumps, which is definitely more noticeable on the left-hand side. I can also sometimes feel a slight vibration/looseness through the steering wheel when going over rough surfaces.
I’m also getting creaking when turning the wheel at low speeds but I’m not sure if this could be related to another issue.
I’ve recently had both front shock absorber and top mounts replaced. The car feels much better since then, but the rattle/knock was there before the work, so I don’t think the shock/top mount replacement has fixed or caused it.
I’m thinking it could be the inner tie rod causing it as I’ve taken the wheel off today and I can feel a bit of freedom through it when someone is turning the wheel
Any ideas?
See attached video of noise
