skyrocketeer
Asphalt pilot
Feb 1, 2016
91
7
Newport S.Wales
2014 plate, manual 1.4TSI 150ps, about 85K on the clock, FSH. It doesn't get driven hard much given local traffic, but occasionally when I put my foot down it pulls well and smooth to 4k hesitates a little then carries on. Does this regardless of driving mode, but only once on a given run, so if I try to recreate it'll pull straight through the revs. VCDS doesn't report any engine issues.
Any thoughts or ideas what might be causing this?
I've got the same issue... Did you get to the bottom of what causes it?
Over a year later, up to about 84k miles on mine and the issue is still there. I get the occasional misfire code for cylinder 1 and 3 but nothing else.
I decided to pop the intake off and take a look at the intake valves. I think they may need a bit of a clean up but I'm not totally convinced its causing the issue.
I don't suppose you have found a fix?
Cyl 1
Cyl 2
Cyl 3
Cyl 4
