Mobbs69
116
15
57
Northamptonshire
Hi guys just a quick question I'm going to fit some H&R lowering springs on my Leon cupra mk3 just wanted to know if I need wheel spacers because it say's the springs are 35mm drop or do I not need spacers
I put these exact springs on my Leon 5f 184.
I don't have spacers on, though I kinda wish I did haha.
Reactions: Mobbs69
Nah mate, tbh after I put them on I kinda wish I went 40. I only went 35 cause the roads round my way are next level shite.
Back
Front
Reactions: Mo_86
I swapped the stock 19s on my Cupra for 18-inch VW alloys with a bigger side wall cuz of our extensive potholes and defects…
I want the 18 Cupra R alloys they're sick!
But yeah, our roads are savage. Thought it was just Lincolnshire ?
Whole of the UK by the looks of things. And the councils answer is ‘Unfortunately due to budget restraints we are no longer able to carry out this work this year.’ That was last month for a job scheduled this time last year…
Reactions: Carnifekt and Mo_86
When I see people talking about fitting lowering springs. The first question I have is, why given the state of our roads and speed bumps.
Second question is effect on tyre wear and steering/suspension geometry. And therefore, handling.
Wi
Please post your pics here when you're done keen to see the difference mate!
Will do mate
Because my other seat handled better after I changed the springs
1. Handles much better, is a lot sharper in corners. Speed bumps don't phase me as long as you don't take them too quickly...
2. Tyres wise I go through a set of fronts once a year, and rears last about 2-3 years. Not including the change for winter tyres.
Reactions: GORDYDJ and Mobbs69
I'm putting H&R 35mm drop on my cupra mk3 300 I was just worried it might rub that's why I asked this question guys
Keep in mind the 35mm might not be a 35mm drop on the Cupra because it might be 35mm on an FR, slightly less of a drop on a Cupra because they're slightly lower from factory. I had the same thing to consider with my Eibach springs.
That would be great all i want is for it to be stiffer because I'm only changing the springs because I've got a slight knocking on the driver's rear when I hit bumps so I assumed I've got a broken spring
Ah, in that case I highly recommend going for the Eibach Pro-Kit springs… they lower 30mm on a standard Leon but on the Cupra it’s 15mm front and 10mm rear, and they’re fully compatible with the DCC shocks. https://www.demon-tweeks.com/uk/eibach-pro-kit-lowering-spring-kit-eibe10-15-021-02-22/
Reactions: Mobbs69
Huh, never considered this!
Good input mate, great to know ty ??
Reactions: Guyelle
