Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Hi there I've got a Leon cupra MK3.5 19 reg. I'm got a problem with the front 2 window not automatically rolling down and also when trying to roll down the windows with my key it still doesn't work. I remember when I got the car it was fine but now it's not working. Can anyone help???
Did you try the reset procedure by rolling them the whole way down and keep holding the button there for a few seconds more and then repeat the same for the whole way up?
Recently I experienced the same problem, I guess it was after battery was unplugged & plugged back. If the problem persists, check the driver door (42) and passenger door (52) control units using a diagnostics device, such as OBDeleven. There might be a "basic settings missing" fault logged in each and this requires running the "basic settings -> front window regulator, driver side" in unit 42 and "basic settings -> front window regulator, passenger side" in unit 52. In my case, window controls had returned back to their normal operation after performing this procedure. Also clearing the faults manually was needed, if I remember correctly.
I had this problem with the near side front window on my 2018 Leon FR. The dealer replaced the switch unit in the door card completely under warranty. I appreciate it would be something of a coincidence for both of them to fall at the same time, but it may be worth checking.
