Oil temp?.
missmouse
82
8
What is the normal temp for the engine oil to run at? Mine runs at about 104C around town dropping to about 102C on a run.
TheSwede
371
211
Sweden
As mine Leon Cupra R 2018. This is normal, slightly above 100c so water condensation disappear.
H Rafiq
1,216
544
If I’m cruising, not driving in Cupra mode or flooring it, it’ll be at about 80-90°C. It increases to high 90s low 100s if spirited driving. Very rarely can be around 110°C
Apr 13, 2023
My is up to 140 degrees at summer.
At winter after some short spirited driving is 100 degrees.
Should I be worried about it?
TheSwede
371
211
Sweden
Oil temp of 140 c is very high.
I also have100-104 c in mild winter in southern SE. Even in a hot summer day, say 30 c on a "track day" full output, I haven't been near 140 c.
PS Leon Cupra R 310hp 2018 :).
Reactions: AlperUtkuCeylan
tracktoy
813
662
On a track day I run between 73 and 100 BUT i do have an oil cooler fitted.
The oil cooler obviously reduces temps which based on my testing confirmed it can reduce temps by 15 - 20 degrees.
