missmouse
96
9
Thinking about getting a pump to change engine oil. Any recommendations?
Ive seen manual & electric for sale on Amazon quite cheap but mixed reviews.
I dont really trust the plastic sump plugs so rather just not disturb!
Can't answer about pump but can you not fit a metal plug or does that not work with plastic sump.
Using a pump to suck the oil out doesn't remove as much of the oil as draining it out does. It's not recommended.
The plastic sump plugs have been around for years now and I've never heard of any issues with them.
Exactly, just use the plastic sump plugs. If you dont trust it, swap the pan out with a steel pan and optionally consider a Fumoto or Steelbus oil drain valve.
The rubber O-ring in your current sump plug does not have eternal life and you should replace it anyways in the (near) future.
I like this more than a steel plug to be honest. I have seen more people overtighten a steel plug than this plastic plug. You just twist it in, no torque is needed
Reactions: RUM4MO and tracktoy
I use a Pela 6000 oil extractor on my canal boat.
The cheaper ones are less reliable.
Reactions: missmouse
Just buy your plastic sump plug from VW Group dealership, or buy a trusted aftermarket brand.
They are so easy to fit correctly - once you have changed one you will find this out, don't worry about it - I even bought the correct tool to remove/fit them, didn't cost much. From memory, I bought 2 the first time "just in case" - if buying online, doing that makes sense to save on P&P.
Edit:- plus, if you are the type of person that is just pumping the engine oil out, replacing the oil filter then refilling the engine with new oil - you have only carried out a basic oil and filter change, you will not have been able to check the underside of the car over - and that needs doing, maybe boring and not something that you want to chat to your mates about, but needs doing periodically, as well as checking over many other areas of the car - like brakes and tyres including the spare (if applicable). I tried using an oil pump once, a Pela one, got really bored waiting for the job to get done even with warm oil, then lots more time to clean the Pela out - much easier and quicker dropping the lot out quickly through the sump plug, decanting into "holding container" then cleaning your "oil catcher" and funnel up. I knew beforehand that I was wrong to use an extractor - but I felt the need to buy one.
Getting the oil out of things like boat engines and gearboxes where a dedicated lift pump is not fitted or available, is more the place for these Pela oil extractors.
I reckon this is a duff idea. Save your money and just let it flow out like mechanics worldwide do.
Reactions: Mo_86
Im actually a mechanic for 40 years ;)
So why did you find the need to ask these questions?
Erm, because this is meant to be a forum for members helping each other out?
I was simply asking if anyone had any recommendations as to which pump to buy.
So sorry if that offends you.
Pela pumps used to be everyone's favourite. Personally, I've had a cheap Chinese oil suction pump at work for years and it's never let me down. It was less than £50 and holds 9 litres.
Two or three oil changes ago, I tried an experment with a suction pump I borrowed from one of my mates, I used the pump to extract all it could, and it certainly took the majority of the old oil out. Once it had finished its job, I opened the drain plug and took another 470ml out. Nuff said!
