Seatbelt Clips
PhilG
16
Afternoon,
have a question. re the 2023 Formentor. the seatbelt clip the end attached to the seat , the bit you clip into. Is it possible to extend this, as mind on both front seats is actually below the seat edge. it is very difficult to get a hold of it to clip the belt clip into. Can these be adjusted to a longer length. thanks in advance.. Cheers
SRGTD
2,751
1,610
I don’t have a Formentor, but something to consider is that if the buckle assembly that the seatbelt plugs into is an active part of the car’s seatbelt pre-tensioning system (I don’t know if it is), then I’d guess on safety grounds it ought not be modified from the original factory spec by extending it.
PhilG
16
Hi th
Hi there , Yes I don't know if it is either. it is really thigh to get to when your ass is in the seat. I was wondering about seatbelt extensions. As you say i wouldn't want to modify the existing set up. Thanks for your response.
