May 31, 2020
10
Yorkshire
I’ve got a bit of a weird request but feel like this is the only place to ask lol
so it was raining the other day camera was covered in water droplets so went to use the rear camera wash function… nothing happened had a look at the camera I don’t see any sort of sprayer nozzle so that’s it then I don’t have the function right? inspecting it further the back window had no screen wash coming out either despite the pump running & reservoir full
so now I’m 50/50 does it have the function & it’s broken somewhere or it doesn’t…. I’m not booking it in for warranty work if it doesn’t (I don’t use the back window so back window screenwash is useless to me) can everyone who has time do me a massive favour & take a pic or video what the reverse camera washer nozzle should look like idk if it’s hidden or what
(it’s a Cupra LEON FIRST EDITION the hybrid version 245)
It doesn’t have a washer, however it can be fitted. It’s a service we offer
Reactions: Slavixs and Legojon
Little upgrade from VW id buzz
Hey. Which bracket and camera housing did you use here? Do you maybe have the OEM number? I did such an upgrade in the Macan, but in the Leon I can't find the bracket and housing
Hej. Jaki bracket i obudowę kamery użyłeś tutaj? Masz może nr OEM? Robiłem taki upgrade w macanie ale w Leonie nie moge znaleźć bracketu i obudowy.
you just buy a camera housing and mount it. there are only hooks on the sides. the camera has no additional protection. you just slide it into it. the same with the spray nozzle.
HERE is link to buy
To jest wszystko w jednym. Ten plastik ma na sobie zatrzaski z obu stron. Kamerę tylko wsuwasz w to. Tak samo dysze spryskiwacza. Jedne co to musisz podciąć półkę na której zderzak leży bo koliduje ze spryskiwaczem. Ale to jest niewidoczne pod nim
I am also interested about details. Can anyone give me housing part number, and hoses details, I found the nozzle
I will try to use 3JD807210A but there is similar - 2GG807210A..
The first one in aliexpress comes with nozzle already!
I will wait for you to report back with the results, please let us know if it fits and if you need anything else to install it (hoses for example)
Reactions: Slavixs
