Nov 9, 2024
9
Hi all,
This is my first topic in the group, I had succeeded in changing the red color in doors for my FR 2022 ehybrid to select from 12 colors. (i don't have smart ambient light)
Of course by using OBD 11 long coding, as it's not available in 1 click application
Hi all,
I don't have the smart ambient light too and I was told that I could not have it after buying the car, do you know if that is correct or is it just electronic disabled or if it can be "turned" on using OBD11 for example ?
Regards
Hi all,
Trying to do it myself would you be able to help. Same car apart being 2021
Regards
Wrap around lights need to be installed from the factory. I have the option to turn them on and change colours but don’t work.
The 12 colours can be added. I done it through odb and works perfect.
If anyone is wondering about coding the color selection:
To have it select the color by drive mode:
Go into:
09:
Adaption:
-ambient lighting:
>Farbwahl_ueber_fahrprofil > installed
>Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default > active
>Ambiente_Farbwahl_FPA_waehlbare_Kopplung > active
To select the color manually:
once you have enabled the menu from:
5f:
Adaption:
-Vehicle menu operation:
>menu_display_ambient_illumination > active
>menu_display_ambient_illumination_over_threshhold_high > active
09:
Adaption:
-ambient lighting:
>Farbwahl ueber HMI > installed
>Ambientemenue mit allen Zonen > active
>Ambient_Farbliste_HMI > active
-interior lighting, parameter:
>p_farbauswahl_HMI:
this is binary, so 0 is disabled, 1 is enabled. I have no idea in which order the colors are, but basically just add 1's to enable more colors in the list of color selections.
If this doesn't work for you, maybe do the same with "p_ambienteumfang_HMI"
Depending on your car, you might have to define the selectable color channels as well!
However, I think this is only on older cars and I have no idea how to do it :s
Let's hope your car has them predefined ?
Otherwise reply #3 talks about it in this thread:
Reactions: gale7
