RxFlow
21
Hi all, MK1 cupra with 1.8t
Had a few issues as of recent with hot starting, noticed when I went to fuel station and filled up, car would then not start when "filled" (only had a 20 on me I'm broke)
Cranked fine however sounded like it was cranking completely dry, engine light thrown on and no start had to wait around 20 mins while occasionally cranking to see if it would start and cycling the key,locking unlocking etc.
Had my handy code scanner with me as it had done it before, codes presented to me were n80 purge valve open circuit and codes for all 4 injectors open circuit, heard about these cars struggling with fuel pumps and relays overheating, the car is running stage 2 and the fuel pump has previously been replaced with a performance one not sure of brand and wonder whether my issue would now be the relay causing the injectors to go open circuit as I've heard that the injector control is also powered by the fuel pump relay , is this correct and what are you guys opinions or where should I start, believe the n80 has been deleted and a pipe in situ that's vents straight to the wheel arch so I don't think it's actually fumes backing up in the tank causing the no start (very naughty I know)
TIA
My first thought was tank vapour issues, but with your set up it can't be.
I'm pretty sure the N80 and injectors are powered from fuel pump relay, so that would be the most likely cause. I'm not usually one to suggest throwing parts at cars, but given that relays are fairly cheap, i'd just swap it out and see what happens.
Wiring diagram https://drive.google.com/file/d/1PysokT7RjHc8Pr_nXBRA-lYKcS8UDmtS/view?usp=drive_link
Just to add to this, I know its very late reply, however i suppose better late than never, replacing the fuel pump relay fixed my issue, just so that anyone who comes here with a similar issue has something to go off.
Appreciate the help and support on this one, was driving me nuts...
No worries, glad you got it sorted! :)
