william griffiths
8
Hi all,
Weird thing happened yesterday, just left the house and the yellow warning triangle flashed up and yellow bulb fault lit up, went into reports on media system and it stated 2 faults, check rear offside taillight and check nearside tail light, so pulled over and checked but all was working fine, turned off ignition and started car again and it cleared. Is this another one of those common faults I keep hearing about?. Car was in dealership the day before to have the sunroof switch/ interior light panel replaced as this was faulty, apparently told by dealer it was a common fault even though car is only 3 months old!.
Hi all,
I had a similar issue, but mine was for turn signals (indicators). Mine also cleared when car was restarted.
Hi all,
I got the same warning too in my Formentor Facelift. It fixes itself when you turn the car off and on.
The fault gets thrown up due to the animation being on for some reason. If you turn it off it will not come up again . My dealer reckon you need to let animation completely finish before opening door then it won’t happen, don’t make sense to me so I just knocked it off , been 3 months now and not had it again
