Mar 18, 2025
Hi everyone!
I have been browsing the forum and found several topics regarding upgrading the steering wheel, but did not really find the answer in them.
I currently have a '22 formentor, with the 'default' steering wheel (attached a photo).
It is a heated wheel with ACC. I am looking to upgrade it to the version with travel assist and the buttons for mode select and start stop.
My main question is, has anyone attempted this themselves and how difficult of a job would it be?
I am quite new but I have some technical knowledge. I understand I need to buy the steering wheel with the buttons, but in a previous post there was some mention of parts for the heating, but since I already have those for my current wheel, can I just use those?
Thanks for taking your time to read my question and for any replies! :)
You'll then need a new slip ring. It has two additional connections for the Cupra button. The driving profile selection is done via the LIN bus and must be coded in the gateway.
Reactions: DidierkeNL
Hello, in Greece our best retrofitter has already done that .
You need new slip ring, new steering wheel and also new airbag because the plugs at the airbags are different, our retrofiter change the plugs and use the same airbag.
If you have the basic steering wheel but with the XL Safety package (travel assist) then you can fit only the bottom part of the supersport steering wheel + slip ring
Reactions: cairus
Thanks, I forgot about the slip ring connector. The airbag cable is also available separately in the right shops.
That's correct, but every VW part has a spare part number. VW doesn't approve every spare part as a spare part. But apparently there are people who have this number and can get the part. If you have someone with the equipment, you can easily read the number by removing the airbag and reading what's written on the sticker next to the airbag cable.
Reactions: the_winner
Let me give this topic a kick, any done this conversion successful on a Cupra Formentor in the mean time?
And is willing to share the information?
Any one know which Kufatec wiring or connection adapter you need for using the airbag?
The supper sport steering uses a different airbag connection.
Maybe someone knows witch pins to reconstruct for the airbag?
Hello ,
i have made a complete supersport steering wheel retrofit + ESP/TCS Button
I don't know any kufatec wiring .
You need a steering wheel, Slip ring or complete indicator/wiper module-leveler , new airbag or repin at the existing wiring .
I don't know any information about the repin and the wiring and the coding, i gave all the parts to a vw retrofit specialist and he made it .
Some photos from the project :
Reactions: DeMelkBoer
To make this post some what more compleet for others, thanks to member Grabania for the input.
Ignore language from the photo, colors should be sufficient. Few details:
- blue wire from horn should be repinned from black 5-pin connector to yellow 12-pin connector
- two additional wires have to be added (yellow and green).
Parts list:
- 4B0971978B - 6-pin black connector - https://s.click.aliexpress.com/e/_c4PKgMcf
- 4H0972208F - 12-pin yellow connector if you have slip ring with index G - https://aliexpress.com/item/1005008769306233.html
For examble, 6 Pin are MEB Cars. And this Airbag Connection is own Sparepart.
You need only the correct black Connector , the yellow you can Take the old one
Hi everyone! I’m looking to do a modification like this, and I have a question for those who have done it before: if I replace the Start/Stop button on the center console with an ESC button, does it require any additional wiring? Also, for the start button located on the steering wheel, do I need to run extra wires through the slip ring, or is coding alone sufficient?
