Rainman
68
9
I just purchased a Cupra formentor 1.5 tsi 2025 MY….i was searching for the dip stick to check oil levels ..didn’t managed to find it ..never the less I only managed to check oil levels through central infotainment system …is this the only way or it’s me that’s blind and I can’t locate the dip stick ..
Thanks for the reply the_winner but it’s not like this the 2025 MY ( as in your pic)
Where is it in the info system , wish screen was it under
Sent from my Pixel 8 Pro using Tapatalk
If you go to the car app from there at car status … it has an option check oil levels … it shows a virtual dip stick with your engine oil measurement
Reactions: Spivvy
I am sure that the engine is the same with the previous one , so you can add a new genuine dipstick that you can buy from the dealer . Like audis…
I a, not sure you can do it …as doesn’t seems to have by design ….what it needs as you may see in the picture of the engine bay above ..
I see the picture, somewhere at the cylinder head you will find a plug , if you remove the plug you can install dip stick . In Audi and BMW is like I told you , with plug .
your engine is the same with the pre facelift model which has dip stick .
Thanks I will ask about it at the dealership
ok i double check it from VW ETKA program ,
Your engine use this plug with part no: 04E115418B they have this plug at the hole where the dipstick goes.
You can install the dipstick with part no 05E115611B
Reactions: Freddy
Hey guys,
By the way, what oil does 1.5 tsi Cupra, 2025 model take?
It seems that the low oil level warning popped up (after 5k km, pretty weird imo) and would like to fill it a bit.
Hey guys,
This is the first car that I got new and hadn't oil level at top from the manufacturer; I got it with less than half filled, so it is reasonable that after 5K you have to top some oil (I had after 3K...).
I think the oil type is not the same for all climates, so I cannot comment about the oil viscosity.
Regards, __Yehavi:
Regards, __Yehavi:
The climate is temperate-continental. East Europe more exactly.
