Do you not charge it when it gets low, I normally do?Same engine at the Terramar might struggle since the car is heavier. Hence economy won't be the same as the Formentor. I owned a Formentor for 3 years, 1.5dsg, great numbers in consumption especially on the motorway.
Now as for the Terramar 272, I have only done 400km so far, one charge at 100% when I got it. 5.6 lt/100km but I will revisit this number. Expect it to be more economical for sure.
I only had the chance to charge it once so farDo you not charge it when it gets low, I normally do?
I only had the chance to charge it once so far![]()
400km so the battery must have been depleted for most of that.Same engine at the Terramar might struggle since the car is heavier. Hence economy won't be the same as the Formentor. I owned a Formentor for 3 years, 1.5dsg, great numbers in consumption especially on the motorway.
It's more complex because you can press a button to maintain the current charging status. Which keeps it there plus increasing it to some extent with regenerative braking etc. Today I will run on a trip with EV mode only and come back. I start at 80%.400km so the battery must have been depleted for most of that.
If you could have a look with battery depleted I would appreciate it as I hopefully will be ordering this week.
I maintain 20-80% as much as possible, I will only charge to 100% when I know that a long trip will take place (which is tomorrow!).Do you not charge it when it gets low, I normally do?
Get the mode 3 as well, AC 11kW, 16A.I got 2 cables with the car. The 3pin UK household plug one and the mode 2 one.
I usually keep mine charged to 80% but occasionally take it to 100% if I'm going on a long journey.I maintain 20-80% as much as possible, I will only charge to 100% when I know that a long trip will take place (which is tomorrow!).
You can maintain charge level if you are proactive driver, press a button in the infotainment system.
Like mobile phones. You would not want the battery cells bloating like mobile phones and tablets of old. The 80% is the new rule now across devices it seems.
If its anything like EV a 100% charge is fine if using shortly afterwards.I think occasional charging to 100% should be OK. Guess I'll find out!
So after ..popular demand, I depleted the battery today from 80% to 1%. I didn't notice tbh, otherwise I wouldn't have left it to drop that much, I will try not to do it ever again.400km so the battery must have been depleted for most of that.
