2.0 TSI estate- suspension and MPG
rock3g
15
Not many of these about (2022 that I have seen), any owners confirm if the rear suspension is torsion beam or multi-link?
Also, realistic MPG? Quoted is 38-42, hoping this will be a suitable replacement for my 2l TDI 150ps 65 plate Leon ST seeing as there are zero diesel 150ps MK4 second hand in the UK..
Cainy1989
99
44
I can't say about the suspension, but the MPG I wouldn't believe the quoted figures, my 1.5 Formentor is quoted to get 42, I am lucky to get 34-36. So much so I am looking to change to a 2.0 TSI or PHEV. The low MPG wouldn't bother me if my 1.5 had a bit of shove, but it doesn't one bit. Coming from a 2.0 TDI myself the 1.5 MPG was a HUGE let down
serdar_18fr
563
Mk3 Leons with engines up to 150hp were torsion beam, more powerful ones were independent. It's probably the same for Mk4. Best way to be sure is to check by VIN. I can do that if you don't mind sending me VIN, via PM. Or you may find it easier to crouch at the rear and take a look under the bumper :)
Sent from my 24122RKC7G using Tapatalk
MA1601
59
17
The 2.0 TSI came in the estate in the UK?
rock3g
15
I'll see if I can get the VIN.
The 2021 brochure says over 110Kw and PHEV is multi link but I wanted to check this was the case. The cars 5+ hours away so looking isn't easy :)
Reactions: serdar_18fr
serdar_18fr
563
While writing my reply, I was thinking that you were talking about your car. Only later realized that you were looking to buy :)
istoyanov
82
11
Bulgaria
2.0 TSI 190hp is multi link!
Re consumption.
