H Rafiq
1,164
537
I’m removing a Powerflex dogbone mount insert on my Cupra 280. I’m replacing the bolt with a new OEM one, and not installing another insert, I’m reverting back to OEM. What’s the torque for the bolt?
Reviving a thread, as I'm installing a yellow powerflex insert.
Did 75nm +180deg work out ok? I'm seeing 130nm elsewhere but have no clue which is right.
Out of curiosity, What prompted you to remove yours? Vibration?
Really appreciate some guidance
Thanks!
@DEAN0
@H Rafiq
@CupraST300 I also had installed the yellow Powerflex one, but I also removed it in the end. Under certain circumstances, it will give hard clunking when upshifting (in my car at least). Usually in D, with 50-60% throttle.
Other than that, I don't notice any real negative side effects. I have new OEM engine mounts (fluid filled) and also a fresh dogbone. I recently installed a aluminum insert (only bottom part) and this gives me a better experience than the Powerflex full insert. The clunking under that circumstance has been reduced with like 60-70%, which is ok for me now.
I installed 'NEU-221093 Neuspeed Engine Torque Arm Insert' in my 300 and it completely transformed the car! When I first got the car and put my foot down I thought I'd been attacked by an Apache Gunship! Slotted the Neuspeed insert in with not trouble whatsoever and its tightened everything up, bets upgrade I've ever done.
When reversing there's a very slight vibration but putting your foot down (going forwards) it just goes like a rocket smooth as anything. Before I could barely hold onto the steering wheel!
The standard soft floppy thing is just not strong enough for the power the engine puts out.
