Model Year 22/23 Issue with infotainment restarting and dashboard errors
May 24, 2025
My infotainment keeps restarting, then i'm getting all these errors on the dash, has anyone seen anything like it before.
Attached is a video
MJ
5,624
55
Manchester
The errors on the dash are directly related to the infotainment system going offline.
What software is the infotainment system running?
May 24, 2025
MJ
5,624
55
Manchester
There is a service bulletin for an update to version 1969. The issue you are experiencing is mentioned in the bulletin.
If it's under warranty then I'd get it booked in with your local dealership.
May 24, 2025
It is, out of curiosity should there be a cover on the ODB under the drivers side. There isn't one, and the fault happened immediately after getting my car washed.
I just heard that apparently the place I got it done may have cloned keys before, I am wondering if they may have plugged something in to have the car away, as the fault started immediately after I left
cairus
1,591
555
I know what you meant by the new key. Generation mqb EVO...yes, it's possible, but it's not a €50 tool. We're talking about €2,000. I won't say anything more on the subject..
MJ
5,624
55
Manchester
And that makes a complete clone of the key? I don't mean program it to the car, I mean read one key away from the vehicle, write the info to another and then have it successfully open and start the vehicle without any programming on the vehicle.
It used to he a thing a long time ago but I wasn't aware that it was even a thing anymore with the CP and rolling code transponder systems, hence the rise in relay theft.
