Clutch pedal stays down intermittently
Jun 26, 2025
Hi, I have a 2016 Leon FR which had the clutch slave cylinder replaced last summer, a few months later the clutch pedal stayed down, I pulled it back up and drove off, my local garage, where I had the cylinder replaced, checked the car over to see if there was a problem, they said it was Ok. It's been fine up until today, where it's happened again, fluid level is fine. Any ideas why this intermittent fault happens. Thanks. Paul.
Jun 30, 2025
I had that too on my 2016 FR. My local garage replaced the slave, still kept doing it. Replaced the master, perfect no problems at all.
I can only assume yours is doing the same thing mine was and goes away when replaced.
Reactions: nd-photo.nl
