Turbo cutting out
Jun 30, 2025
11
Hi guys, not sure if any of you have more knowledge than me, or the local garages in my area. I’ve gone to a few with no avail. I’ve had my car “seat Leon mk3 184bhp 2013 2.0tdi” for a while now and had no issues. Suddenly. When my car gets to operating temp “85-90” my turbo cuts out. From turning the car on up until 85-90 the car feels completely fine, no lag in the turbo making me believe the turbo is fine, not loss in power before 85-90 making me believe it isn’t a boost pipe. I’m at a loss with this and if anyone can help save me from the torment and the hassle of finding out what it is through going to garages nonstop thatd be great.
thanks
SuperV8
1,872
941
Jun 30, 2025
11
Can you explain the problem in more detail?
Is it a sudden power cut - or a gradual fade in power?
Why do you think its the turbo?
Crank sensor can cause sudden power cut:
The car is working fine until it hits operating temp and all the turbo power goes, the car has a air intake so you can hear the turbo soon as it hits 85-90 the turbo noises disappear and so does all the power
Jun 30, 2025
11
Yes that’s the bizarre problem no codes show for the garages, I had a code for P2456 when I scanned it on obd, but nothing shows for them
ill give the crankshaft sensor a go tomorrow hopefully that works if not got it booked into a vw specialist for Monday
Jun 30, 2025
11
@SuperV8 I had a crank sensor issue on my Golf 3 GTI, once the engine warmed up it just stalled :wtf: Waited for a little bit to cool off, then it would start again and run again...
Mine still runs but the power just cuts out I’ve ordered the crankshaft sensor and the dpf sensor as I’ve seen that these both can cause this problem
Jun 30, 2025
11
Yeah it’s super annoying, bought the crankshaft sensor and dpf sensor will fit them and hopefully that fixes it, if not it’s booked into for a VW specialist
cairus
1,578
552
You misunderstand me. The vehicle calculates the boost pressure the turbo should produce. The turbo measures the actual boost pressure. Have you ever recorded these parameters during a drive?
nd-photo.nl
4,429
503
The Netherlands
youtube.com
With a proper computer/software like VCDS or an Autel you should be able to log this. What @cairus means is that the car requests a certain boost and the turbo tries to delivers that boost. Those 2 values should ideally be very close to each other. If there is a big discrepancy, then something is wrong (for instance boost leak etc)
