Well the Mib2 high screen turned very blue yesterday. Vaguely remembering what people have said in the past that they change colour in freezing weather... I did nothing. Glad to report after it warmed up it went back to the correct colour ?.
Edit: History piece now. Nov 2026. TMC fix was good for 3 years then the service was pulled.
TMC working fine on mib 2 ?. I did post up the solutions with the links on the bottom of this, on TMC UK Solutions:
Inrix works better than Ttraffic Master so it would appear, better data feeds.
Virtual pedal and the cat !. Scored yesterday, ran under the back when I was calling him in, seconds later the back raised nearly hitting me. A fault, what caused that ?... no we know how that happened :). Children and pets have that ability to generate the pedal action if you happen to be standing at the back with the key and they swipe underneath. 99.9% of the time it doesn't happen. Hence the warning beep ⚠️ beep they built in
Changed the remote battery.... the dealer must have changed it when they did a Kessy update. 2025 not the 2032 hack. I admit I didnt take the anti bite sticker on the new one, I forgot to take it off, but did test before I clipped it up. No red light. That red light is the telltail without getting the meter out. I'll blame on the dealer swapping out months ago the 2032 for reasons unknown. Expect the firmware update or whatever didn't go well so though... flat battery.
Morel here... make sure you take the anti bite sticker off when changing the battery even if flummoxed.
Fifth service at our local VAG indie (MD Autobahn, Salfords, Surrey) and MOT.
Having bought this car new in July 2020, the plan was to p/ex at five years for another new one. However, it's only done 20k miles in that time and is still pretty much as new so I don't see the point. Sale postponed!
Reactions: Tell
No point in replacing something you are happy with. They are pretty reliable cars.
Hmm, it's had a few blips here and there over the last five years. The latest, a few weeks back, was the driver's door electric window doing it's own thing. A few days later it was okay.
Compared to our other cars, present or past, it's been the only one with tech issues.
I haven't had the window motor give way yet... but on all previous cars yes. The ABS did play up a year ago. Two sensors down and it upset top view, the reversing camera and a load of errors on the dash. I did a Obdeleven clear errors. I was on holiday. It fixed for a time then off it went again. Dealer knew exactly what it was when I got home and Obdeleven did report ABS... just that once it picks up that fault it then terminates top view and the reversing camera.
£xxx many down, ABS sensors replaced as good as new. The other one was a pollution monitor sensor, being a diesel throw a raspberry on that. Failed sensor that triggered the warning. Still driveable. The ABS issue made reversing tricky with no camera.
With more tech in the car you can expect more to go wrong.
I slipped it into 4drive in the snow and ice. No issues. The power switched between the wheels. I sense it with 4 drive. Sheer black ice outside. I notice the neighbour slid out with their wheel turned :oops: . 4 drive is handy when you need it. Those all weather tyres above.
New tyres:
View attachment 18281View attachment 18282
The Ateca became a self respecting 4Drive on all weather tyres today, got the discs and the rest done. After four years the factory fitted Bridgestone Dueler were showing wear and the rubber was cracking.
These will be good for any snow we might get. Live 1.5 miles off the main road up a hill in rural Wales in a village... these should stop you from getting stranded in or out - we hope. No discernable sound difference.
Nb. They are Crossclimate SUV, reviews:
New tyres again. Crossclimate 3 this time. Too new for the tyre reviews website.
Yes and after ten years the fancy alloys are not so fancy too look at.... not bothered thou.😉
Edit ... rank 2 now. They will do.
Bulk update to the radio logos after someone in the dealership fumbled mine out:
The source of radio logos for bulk updates is provided by PhonoStar contracter to Vag group for all infotainment variants these days. We use the research done by MartiniB to find these files. I had done the individual ones before for the mib2 but went for a bulk update this time on the basis that the tricky ones are now in the file.
Mine is a mib2 high taking the correct file. That was fine. No success on mib2 standard with that file thou. Tried to update the logos in bulk on the other car. Wouldn't take. Possibly the part code is missing out of the file. So mines sorted out.
This link provides how to do the odd one. Can be used to in fill anything missing:
That works on a mib2 high or standard.
And all done with the bulk logo update on a mib2 high. That shows the current version of the logos v1.10.70 direct off the Phonostar press. It may be ahead of connected cars. It's a production line of logo collections. Customers of mainly VW nag Phonostar to get the logo files updated so on connected cars they see a logo atleast in Europe. These get distributed via connected cars upload or for non connected cars you do it yourself.
I used the swdl import but just a normal update would be fine where it says update in settings (possibly not a mib2 standard). First time I've done that with radio icons as a bulk file update.
In mib2 standard and high they sit there from when the firmware was originally installed. You can update the icons separately it's how the system is designed. They are like parameter files of old. The program reads them in. The core software isn't changed (firmware).
Mib2 high the maps get stored on the SSD in the unit. I always updated those six monthly but hadn't touched the radio logo icons so they dated to when a retrofitter fitter updated the firmware circa 2017/18 except where I'd used a facility to do a simple logo import which is missing from mib3.
Basically logo are transmitted over the air for certain stations, BBC and RTE to name two in the UK and Ireland. The commercial stations may not all transmit the logos and really on the cars logo database as the source. A miss match of the station ID being broadcast on FM and DAB to the cars logo database in the infotainment unit can produce the wrong logo showing the old station not the new one. Mib2 has that fix of simple logo import which I covered using a filling file. At one stage VW provided these on their database. That was taken down. You then used the mediainfo website for VW, that was taken down, there were home brew alternatives for the logos or you used Google images, now Glass to make your own.
Anyhow with Phonostar being the contractors to VAG now for "European" logos to do the work those files are now distributed across the infotainment units but as import files which wipe what you have and put in new ones.
Gracenotes is another file I dont update on the mib2 high. Other people do who are into album art. I had just put the cover.jpg art 🎨 in <= 512x512 file in the album of an SD or USB. That is read and throws up the album art. Without that, Gracenotes reads the finger print of the album and digs out the art or close enough. Those who play mp3s probably cherish Gracenotes on their mib2 highs.
User POIs in mib2 high or standard are also held in the unit. Can be speed camera or user defined locations.
These files are all entities that can be imported into the unit.
Anyhow screen below updated radio logos to v1.10.70 summer 2026.
Ps I have a theory that the dealership though they were updating my logos on the basis that it was a mib3 and they were already in the unit, so deleting old ones for the BBC etc would magically lead to the new logos appearing....they were only changing the oil.... a little peeved to find my carefully created station list and logos vanished when I got the car back. So yes that's what I did with the Ateca mib2 high yesterday.
Twas an Adblu day today. Easy enough at the pumps. It is a ferry route so an Adblu pump is placed at the filling station. Slight delay waiting for a lorry to clear the pump. How I do it, no slopping about with bottles, use a lorry / van pump. Keep a bottle of water 💧 in the boot to wash down any spillage. There wasn't any.
