roverman1
11
I'm need a new rear right brake caliper for my 2015 Leon 1.2 estate, but I need to find out the brake disc size, I don't have a pr code for brakes in my service manual. It has a manual hand brake. Would the discs be 253mm? . Cheers.
Hi, best way to find the exact original part number is to look up using VIN.
I have access to the official parts catalog and I can look it up for you if you send your car's VIN to me via a private message.
Cheers,
Serdar
That's brilliant, I'll get that sent over in the next. Half hour or so, much appreciated ?
Here are the brake system main parts information for your car:
PR code for front brakes: 1ZE
PR code for rear brakes: 1KD
Front disc size: 288x25
Rear disc size: 253x10
Front caliper housing
Left: 8V0615123
Right: 8V0615124
Front discs: 5Q0615301H x2 units
Set of front pads: 8V0698151S
Rear caliper housing
Left: 5Q0615423A
Right: 5Q0615424A
Rear discs: 1K0615601AB x2 units
Set of rear pads: 5Q0698451M
Hope it helps & cheers,
Serdar
hi i have the same problem got a seat leon fr 1.4 2017 and dont know the size to get i have been told the rears are 253 then others say 272
Only the 184tdi and 180tsi had the 272 disc.
That depends on not only the engine type but also on some other equipment.
For example, my previous car, a 2018 Leon FR with the 1.4 125 engine, had 312s front and 272s rear, because of the DCC option.
Reactions: SuperV8
