Model Year 20/21 Infotainment update failed
Aug 13, 2025
12
Hi everyone,
Today I was updating to version 1988. I uploaded the files to the USB stick, started the upgrade process, and it got stuck and has been stuck in the boot process ever since.
Does anyone know how I can restore it?
Aug 13, 2025
12
Nothing to do, as soon as I start the car or connect the battery cable this screen immediately appears without giving any option to install or choose a boot disk.
luisbento
10
In the first link there are 2 files in the bottom tha say recov.
Use one or another and do what is inthe manual. Use 2 pen drives, 1 for recov and other to the firmware.
luisbento
10
Service Procedure  Refer to Technical Bulletin 00-19-04 (2054866) Set up SD/USB Creator to Obtain Software Updates.  Use USB part number xxxxxxxxxxxxx.  Switch the ignition to the OFF position.  Connect the MTRMSP0702 battery maintainer/charger to the vehicle’s battery.  Insert the USB recovxxxxxxxx into the front USB-C connection.  Switch the ignition to the ON position.  Hold the “On/Off” button on the MIB display for a minimum of 10 seconds, then release.  At this point, it may take up to 5 minutes to the system to start and initialize.  If after 5 minutes, there is no response from the system, the above process may be repeated.  If the recovery attempt is successful, the following screen may appear on the MIB display and additional files may install at this time.
Aug 13, 2025
12
Hi, I created a pen drive with the recovery and one with the update. I followed the guide but the screen doesn't change and it doesn't do anything.
cairus
1,626
568
Es sieht aus, als hätten Sie Ihr Gerät beschädigt. Haben Sie den Akku 30 Minuten lang angeschlossen?
