Loadmaster748
Hola!
570
283
Surrey, UK
After six weeks of ownership I thought "what does the horn sound like on this car?".
Frankly, it's an embarrassment - a weak and weedy single tone 'beep'!
Has anyone replaced theirs, or can tell me where I can actually find it buried under the bonnet?
Thanks!
Can't help with where it is; usually behind a wheel arch liner or the front bumper But when you do find it, replace it with one of these
Reactions: Loadmaster748
Thanks!
Totally agree, my last (22 plate) MK4 FR had a loud twin tone horn.
Thanks!
My previous two cars had sweet-sounding dual tone horn from factory so it was a surprise to me that a fully loaded car like Cupra Ateca came with an awful single tone one. Of course I had to replace it with dual tone using the original parts. Here's my post about that & some other retrofits:
https://www.seatcupra.net/forums/th...ing-due-to-vags-terrible-cost-cutting.478506/
You can hear the difference in videos.
Cheers,
Serdar
Cheers,
Serdar
Thanks Serdar - I'll take a look at the link.
Cost cutting since 2020, our Ateca 1.5 FR has a beefy dual tone horn. :D:D
Reactions: serdar_18fr
Job done. A very nice twin unit is now installed!
Where was the horn located and what did you replace it with? I have ran into an issue with my horn having stopped working, clock spring and fuse are all okay. Horn has died on its own, I plan to replace myself but struggling to find any info online.
It's located within the bumper space, low down and offset towards the driver's side. There's no need to remove the bumper, certainly not in the case of a Leon Mk 4 / 4.5 - other cars might vary!
Remove the engine tray and behind a flap/panel to the forward right side (I really wish I'd taken photos!) you'll find the horn. It's a bit tight for space but the single tone was removed and a 'previously enjoyed' twin horn from an Audi TT was installed in its place. There was some minor wiring involved, not a big deal.
I hasten to add that my local and very helpful VAG indie did this for me in less than 30 minutes - the car was in the air on a ramp so that obviously made the job easier and quicker being able to have proper access and not crawling about on the floor with the front up in the air on ramps/jack.
Much appreciated! Will have to take it to my local VAG garage myself, seems the best idea especially if a lift is best suited to avoid taking the bumper off. Thanks again,
Dit you make photos? And got a sound clip?
I'm afraid that I didn't take any photos and I seriously regret that now. Sound clip? No, but a very decent and loud twin tone.
@DutchCupra75
Here are the before & after videos of dual tone horn retrofit, which required only a new bracket, 2 new horns, a connector, a self-made wiring loom and also OEM bolts & nuts, if you're obsessive-compulsive about the originality of parts like me :)
Before
After
HELP ME OUTTTT. Is the first video low or high tone?! I need to buy on of these, but cant return them. so.. need to be sure
I'm not sure we can call them "low" or "high".
The tone you hear in the first video comes from a single horn.
The second one is produced by two different horns.
