trew
204
188
Here's a good one...
Unlocked the car, pulled the hood lever, did what I had to do in the engine bay, shut the hood, went to lock the car and noticed that all the car's windows were fully open (and the sunroof had retracted halfway too).
Anyone else had a similar experience?
Is it a ghost?
Open button on the fob accidentally pressed and held then the convenience open function has kicked in?
I've come out of the house a couple of times only to find all the windows down and roof open on the car.
Reactions: trew
Thanks.
That's quite possible. With the fob in my trousers pocket I may have leaned against the car (I was topping up with half a litre of oil) and inadvertently long-pressed the button. I wasn't aware of this function - must have a play with it tomorrow.
These things happen. You can turn it off in the infotainment system.
Reactions: trew
I've learned you can turn it off in the infotainment system. You should try it.
Thanks James. It's now turned off - can't see any situation where I'd want to open all the windows in a hurry now that October is here.
