Yes, the genuine Seat FR rear mudflap ((575075101A) is a very close fit, you decide if its good enough from the pics below:
Interestingly, my original post has been viewed 466 times, but only one reply has been posted (thanks, Cosmic Blue). Whilst several of those views are probably just people being curious, I'm sure some must be from people also wanting to fit mudflaps that fit a recent Cupra Ateca.
Has no one else successfully found a solution?
Reactions: Tell
I looked at options for several months, imported rubbish items that allegedly fitted (mine was a 2023 vehicle), but didn't and then noted that a friend's FR Ateca's rear bumper looked tantalisingly similar, took the plunge and ordered a set. With time and patience they could have been made to fit better but I was awaiting a knee op at the time and couldn't spent lots of time kneeling on the garage floor making them fit perfectly. Your original post will attracted lots of views because the Cupra Ateca throws lots of road crud up onto the rear of the vehicle and as you have noted there is no official part for the job - the part number needed is in my post - not cheap though.
If you go down the mudflap road then the mud deflectors for the rear wheel arches that stop crud been thrown up onto the rear faces of back doors is another worthwhile (and inexpensive) mod:
Reactions: Tell
Thanks for the further advice, much appreciated. I think I shall either go for the FR version as you did, or maybe cut some from plain rubber sheet to make flaps that use the wheel arch liner mounting screws. Proper ones would look better, but the car definitely needs one or the other.
As for the deflectors to protect the back doors, I am now on my third order for them since August. The first two orders never arrived and Amazon eventually refunded me. I suppose they are all manufactured by the same firm in China and sold by different sellers through the Amazon platform. Currently, my third order is now 2 weeks overdue, and Amazon is "reviewing" the order before refunding me again.
Once again, thanks for the advice. John H
You are most welcome John H, frustrating with the Amazon order. I had the knee op back in early November, having swapped the Ateca for VZ2 Terramar a few days before. Cupra seem happy to do mudflaps for both ends of the new wagon - equally effective at keeping the rear and sides cleaner. Also the Terramar rear wheel arches have the same 'missing' bit of steel-work as the Ateca does - but the mud deflectors are built into the doors instead, progress. John W.
Reactions: Tell and Speedsport
The missing bit of steel work caused much angst when the Ateca came out in 2016. Some wanting a writing campaign to Seat. I've noticed that design feature in recent models (Cupra). It's to give rear legroom by putting the rear wheel in the cabin... you have to have a longer car to get the proper wheel arch back isolated from half in and half out of the cabin door otherwise.
The only noticeable issue in the Ateca I have had is when I drove through some red sandstone mud from run off from a field, onto the road (ploughing, potatoe digging etc). Red sand plastered in the rear wheel arch inside the cabin. If you were driving through a cattle crossing regularly I could see you'd get excited with muck plastered in the body to have clothing touched on it 🫩. They slip these little design features in without telling you. A visual check of that rear wheel arch tells you. It wasnt the first Seat that had this design.
Reactions: CosmicBlue
@CosmicBlue
Do you know the part numbers for the mud deflectors? Had a quick look on google but only mudguards showing up.
They are not a Seat/Cupra part, unfortunately.
I've tried ordering them 3 times since late September from Amazon, but each time they have been "lost in transit" and Amazon eventually refunded me. I am currently awaiting delivery of a fourth order placed on 4th Jan, apparently dispatched (from China) on 6th Jan, but there's no sign of it yet, and it's now overdue too. I'm not convinced anyone has these for sale any longer, or maybe I'm just unlucky!
See https://amzn.eu/d/dFf73TO, where (in theory) there are more than 10 available. The price fluctuates wildly; they've been as high as £60, but each set I've ordered has been around £20 a pair.
Good luck!
I ordered the wheel arch 'deflectors' again, this time from AliExpress. Given that 3 previous orders placed via Amazon all failed to arrive and were eventually refunded, I wasn't holding out much hope. But 3 weeks after placing the order, the Ali Express ones did arrive, apparently overland from China.
They align perfectly with the existing screws that hold the wheel arch liner in place, and take just 5 mins each side to fit, even with the wheel in place.
However, I don't know if the rubber door seal is now thicker on post-2020 Atecas, or maybe the arch liner now has a slightly different profile, but the deflectors seem to leave a much larger gap between them and the lower part of the door than in the photos posted previously by forum members.
They are much larger than I expected, probably worth the £20-ish that I paid, but not £48+ seen in some adverts.
I guess time will tell whether they work.
Rear Wheel Mudguards Set For Seat Ateca 2017-2021, 1Pair Splash Guards And Fender Protection - AliExpress 201355758
