Hristiyan Dyankov
39
23
33
Bristol
Hey lads! Has anyone done a heated windscreen retrofit? Does anything like that exist for the mk3 Leons? I was told that there was a chance but I cant seem to find a part number or how to to the retrofit. TIA
Mk3 never had a heated windscreen, so no part number.
There may be a very small chance that a glass manufacturer, such as Glavista, might have once offered a heated one.
But a quick glance at their website didn't produce any result of that sort.
Maybe you can try to look further, as you're told that there was a chance, though I'm not sure what was meant by that.
Even if you manage to find a heated windscreen that fits, you'll need wiring diagrams from a similar model which is/was offered with a heated windscreen, like Ateca. And then even if you got it wired properly, you'll have to hope that the firmwares & datasets of related control units in your car would support it.
The only problem is finding the right heated windscreen. Everything else is secondary.
I have too many open projects, Area View for example, which will finally be finished in 2026. Lots of small projects, so a heated windshield just isn't feasible.
Happy to be wrong but I don't think the MK3 Leon came with heated front screen, it uses the Heater to demist from memory.
Seat are now offering it but I don't think it across the range.
ye but one of the retrofiters told me he can do it but the screen was like 800 quid or something like that. So I thought to ask peope here and see if anyone has heard anything like that. Ty for the reply!
Reactions: tracktoy
This company claims to make heated windscreens that fit Seat Leons
But never heard or seen anyone with one fitted.
The web page at the link you've posted states ‘pick up only, sending not possible’. Thinking about the practical considerations for UK owners, as this supplying company is based in the Netherlands it might not be a workable proposition for UK owners, especially if a fitted screen sustains damage that’s not repairable and it needs to be replaced at short notice for safety reasons and / or so the car won’t fail an MOT.
Insurance companies would also be unlikely to pay for one of these replacement heated screens if they’re only available from this Netherlands-based supplier on a ‘collection only’ basis. You’d probably just get a standard non-OEM screen from the insurer’s usual approved glass repairers / installers.
It also makes sense why the original post quoted £800 for the screen (Due to the cost of transport and insurance).
The other point is build time is between 1 - 4 months so not a quick turnaround if you have a damaged screen.
But @Tester01 good spot if you want one then they are out there.
Also says Leon 05 - so would presume this is for the Second generation Leon (1P; 2005) Not the MK3.
Here's another place in the UK that makes them, mostly for rally.
https://www.heatedwindscreen.com/pa... can, just let,with a cost effective solution
They say they can make them for any type of car in the FAQ.
The golf 7 came with the option for a heated windscreen (called climate windscreen), so you could probably wire in your custom made screen, code it and have a clean retrofit. But nobodies done it before as far as I know
https://www.heatedwindscreen.com/pages/faqs#:~:text=Yes we can, just let,with a cost effective solution
Wiring wise it’s easy
I can’t imagine a one off heated windscreen making financial sense but then again if there’s enough people interested it could
Reactions: SuperV8
