I was watching Mischa yesterday and then....
The only difference is that car on that video have OEM ones and mine is 3D printed ;) also mine will be ~5mm wider.
One side completed, ignore alignment and colors
That looks like a lot of fun, doubt I will ever make it there but this year I am going to get a bit more kit for the play station so I can do some track work at home.
On a more Sedentary process I am today updating my OBD11 With all the Build Codes that @serdar_18fr kindly shared with me. so that i have a complete build list in the APP.
I've never driven on the Nurburgring (I dont want to gamble with my own car), but just going there is such a cool experience. Everything around it just breathes "racing". Also the scenery around the Ring is stunning (y)
Reactions: v11boy and tracktoy
How did you do that? and what are the benefits of this update?
From the My Car screen, select Info, at the bottom of the page you can see Equipment this is where I have typed in all the Build Codes.
Benefit is for me that all my codes are stored in one place and easy to find, does not offer any benefit to OBD11 Application.
11 year mark MOT Passed just needed rear drop links replaced and Cat warmed up.
Garage owner enjoyed taking her out to warm the cat up and called me to ask to take the car away before he lost his license :)
Some good news IT STOPPED RAINING and better still I managed to find the cables for the Passenger Seat Sensor so I can now refit the passenger seat sensor into the Passenger Bucket seat, i also saw the heated seat part but that is not something I am going to refit But I do have plans in the future to use the buttons as on off switches for other devices (but that is a way off yet).
Just to share some info with others as I have removed my rear seats completely I can confirm the seat occupancy sensor (my 2014 car came with this as standard) works in the same way as the Drivers seat, basically if the seat belt is buckled up then its assumed somebody is sitting there.
Reactions: nd-photo.nl
So my car decided to not start today, no previous warnings or anything, drove fine yesterday.
Was worried i left something on but apparently it all switches off once locked?
Anyway I've ordered a new battery as the original is a moll efb 69ah, new one i ordered from tayna, bosch agm 70ah 760cca.
The AA came out and checked that the battery was charging just old.
Hopefully the new one works without issues.
Fingers crossed that sorts it.
Reactions: Mo_86
Don't forget to do the battery coding in VCDS as you are changing battery capacity & type (EFB > AGM). Its not mandatory, but highly advisable to get the most out of your new battery (y)
Yes i will do thanks, it may not be done for a few days but that should be ok right?
I see you have the 72ah maybe i should have gotten that rather than the 70ah.
Few days is no issue. Its to make sure that the battery charging system makes the best use of the battery. I doubt the 2Ah will make much of a difference in real life :happy:
I just bought the brand for which I have good experiences with
Reactions: Mo_86
Fitted new NGK Laser Iridium spark plugs (ILFER7C8EG 91898) after my tuner recommended them. More pics here: https://www.seatcupra.net/forums/th...leon-st-cupra-280.477591/page-19#post-5097411
AP1GczNbdFBBnBUeW48c6Wg-vgxy7IqUECCDW7ZxVtbdWIdhXGL-yS8bVx5XkwhUcSG0kB9zc8ZVoLL2OtoCInkzdKLZmazMw7icdcEFj_Q6ooOMOidOiG3orIsmBD4AuHGWoq-T5QNwieGEa6k7lSwzccKwVA=w1920-h1080-s-no
Replaced the over-the-airbox coolant hose with a silicone under-the-airbox hose. More pics here: https://www.seatcupra.net/forums/th...leon-st-cupra-280.477591/page-19#post-5097835
AP1GczO0oNrYPJLZcp0sHg-oe3ocXdPp5YGpujsEkdihq7M8_DSkSdjvXpxhTffCzdXCwMCeug3oVqrNMawl_ABzTTnEXTc4MW8AuzTL2Tu93pBBrfpJ86M0zeUnRGuEcL6AgqPMzraUpa8vXIsC6U-hSE4HVw=w1920-h1080-s-no
Bought the engine bay LED bar, more pics here: https://www.seatcupra.net/forums/th...leon-st-cupra-280.477591/page-19#post-5098303
AP1GczMru4MzesBuEqnhE6blpuuIFgfODWAwq4Jx0aARsJvHuTWEs8YjpqXcm88yiP9gBzdyEf4oASnZXUk42UxTWdu-iHbYznXKh_U47verTLdFHkjoZC9EwazzvJqBnu4qrQNT1WTbgYwRhe6LlsROcNo1Yg=w1920-h1080-s-no
Replaced the hydro filled engine mounts, as it seems they were leaking! More pics here: https://www.seatcupra.net/forums/th...leon-st-cupra-280.477591/page-19#post-5098304
AP1GczM3DbJl7l1eihLkWjx9XucCi-7cG953kKwCi87idSV0UYIwm_ttYaY9LsLVDM5iS5H656pJzh7wJVyqaYO9SKCLl8rrpt5Vqbtm-P0eF5a6jnmC2rTy7-BKNYomKVau1FHPudMuEKVVkea5Wz29mhpFAQ=w1920-h1080-s-no
AP1GczMj6TqXbZEy27wyVigE5juyIeCmfCUlANdB3yB98MXK5ippwa7eTYQrrnlYExSCB9kIqhsZxiRqqJrf6xKkJt9qM92yOXakuMc53n00w1NWBIhEoGDwhO6G_3xVKZhE9nI7D4_PZk8-8ze-xg37bp82yw=w1920-h1080-s-no
Reactions: Mo_86
