Mar 29, 2026
14
I have the facelift Leon FR Technology (2017).
I've been trying to get to the bottom of a few issues with the car. When running a scan on obdeleven the long coding on control unit (09) Central Electrics is all zeros.
BCM: 5Q0937084CG
Long coding: 000000000000000000000000000000000000000000000000000000000000
From looking about online this sounds like the BCM is not coded correctly. Every scan I have done since I've had the car has always been zeros.
I was wondering if someone with the same year and spec could check to see if it shows the same also?
If it is coded wrong how would I go about getting it fixed?
I think that's ok. From memory late 2016 VAG moved long coding to adaptions on this control unit. I only have one 2017 in my garage and it's shows all zeros.
Reactions: Ryan1882
