ExiledWeegie
224
198
Fife, Scotland
Hi guys,
Ive just ordered all new pads and discs, 2 lower arms, 2 drop links and 2 rear wheel bearings, going to do a full refresh of the suspension.
I cannot find anywhere that tells me what shocks and springs i have front and rear, i think with it being a cupra 180 auq it has sports suspension?
im not sure, anybody able to tell me part numbers?
Hi guys,
I can look up exact part numbers for your car if you don't mind sending me its VIN via a private message.
Reactions: ExiledWeegie
Hi guys,
Here's the part numbers of shocks & springs for your car:
Front (PR code: G99)
1J0411105P Coil spring for sports suspension (4 colour strokes, 1 paint mark, green/blue)
1J0413031DP Shock absorbers for sports suspension
JZW413031AB Gas shock absorber for sports suspension
Rear (PR code: 1JE)
1J0511115BF Coil spring for sports suspension (4 colour strokes, 1 paint mark (silver/blue)
8N0513025C Gas shock absorber for sports suspension
Curious thing here is that there are two alternative front shocks listed for your car, that seemed unusual to me.
You may want to check the shocks on your car to see which one it has.
Anyway, hope this helps & regards,
Serdar
soooo today its had a bit spent on it lol
drilled and grooved discs front and rear
febi bilstein pads front and rear
febi bilstein front drop links
febi bilstein front and rear wheel bearings
febi bilstein lower arms and balljoints
killen front and rear springs
quinton hazel front and rear shocks
she better love me for a while after this. :ROFLMAO: should be fun putting all this on when it comes.
Going feel brand new once it's all dialed in, be hugging corners for fun 👍
Isn’t the Cupra R (BAM AND APX) engine cars 10mm lower so that is why there are 2 versions of springs?
If you're referring to my post above, it was shocks that have two versions, not springs.
In fact, there are way more than two versions of each component but the parts catalog should tell us exactly which one is supposed to be used for that specific car, known by its VIN.
That's probably so, but my point was when I query the parts catalog using a VIN, it should show me the part number of the exact shock. If it is an R, it should be just one shock for the R, not multiple ones. (there might be different versions for the different production dates but that's another matter)
from AI...
Part number 1J0413031DP (or 1J0 413 031 DP) is a genuine VAG (Volkswagen Audi Group) Original Equipment Manufacturer (OEM) part number for a front suspension shock absorber strut
Part number JZW413031AB is a Genuine Volkswagen Group (VAG) "Eco" Front Gas Shock Absorber / Suspension Strut, specifically engineered for vehicles equipped with a sports suspension setup. It belongs to Volkswagen’s "Economy" (or 4+) parts lineup, which offers cost-effective, factory-approved replacements tailored for vehicles that are four years or older.
Why not Febi B4 shocks to get all setup along with same brand?
rear end done with
shocks and top mounts, springs, wheel bearings, discs and pads
think maybe next year i'll treat her to a new rear axle and brake hoses and pipes at the rear.
sunday im gonna do the front with
shocks and top mounts, springs, wheel bearings, lower arms, drop links and discs and pads, might grab a couple of track rod ends tomorrow in case they look sh*t then ill get it tracked during the week.
and again maybe next year get a new subframe on her with new brake pipes and hoses too.
today was a nightmare, strut pinch bolt snapped trying to get it out, abs sensor snapped, wheel bearing snap ring became part of the hub after 23 years, what a ballache getting that out,
tomorrow need to source a pinch bolt and nut, an abs sensor and put the track rod ends on and take for it for an alignment then done hopefully.
  • Wow
Reactions: Battoussai
Yeah she can be a real demon when she wants to... may a copper grease fall on your hands to prevent future snaps ;)
  • Haha
