Yeah I found that thread yesterday and was reading it.They would have to be very scummy to find evidence of scored bores on the boscope and then decline the warranty (as long as you have warranty!).
What warranty do you have? Presume it is fully serviced?
Does it use much oil?
My father-in-law's 1.5 DADA TRoc used to use a bit of oil, but he changed from the 508 0W20 to the 504 5W30 which apparently has cured his oil consumption.
Interesting post from here:
Would be very shitty if they declined a new engine.
This video seems to explain my issue from what I understand.
This was the facebook page of garage in Poland that seems to commonly encounter these issues.
DADA engine also
I've got the same tapping issue also - which dealer picked up on.
Car sounds like a diesel
59.520 Aufrufe · 178 Reaktionen | Passat B8 1.5 tsi 150km na przetarte cylindry i słyszalny piston slap😉 | JB VAG AUTO
Yeah its fully serviced kept up with that, its due another service next month again.
It does use quite a bit of oil which we saw from the oil test
After PCV was changed i got the check oil light.
Topped it up and did an oil consumption test after 600 miles and thats when they found this issue as the cause.
Not sure of exact figures but Im going to ask if I get copy of all the dealers findings just for my records.
I had All in One Service + Warranty then due to car being over 6 years when it ran out November last year.
I couldnt get the all in one again, so just got the Extended Warranty Plus, which I believe is equivalent to the warranty cover I had with the all in on plan.
SEAT Extended Warranty
Is your existing warranty about to expire? Is your SEAT or CUPRA out of warranty? Our 12-month policy offers the reassurance that, should a covered component suffer sudden and unexpected failure, you’ll be insured.
However its only valid until 60k miles, im at 52k ish - I dont believe the warranty under all in one had this restriction.
Which is also why im trying to be more aggressive in getting to bottom of whatever this issue.
Tip: (I found this out too late)
If your car is between 3-6 years and you have All in one and approaching the 6 years old mark.
Cancel all in before your cars officially 6 years old and one repurchase it this will give you an additional 2 years of all in one.
These guys have been quite helpful and have made more progress in last 2-3 months vs last 3 years with Lookers.
Just wish I came here earlier.
Warranty claim got updated this morning now back with Seat, so hopefully I'll get the outcome we want.
Thanks to you and others in this thread for all your help in trying to figure out my issues.
Ofc fuel issues still exist but hopefully if I do get a new engine then that'll be a thing of the past.
Will keep you updated.
