James1234
I have recently purchased a Cupra Formentor VZ3 2025 and have noticed an issue with the panoramic sunroof. Sometimes the Sunroof decides to close fully first time and other times it takes 30+ attempts at closing the Sunroof before it actually decides to fully close. On the occasions that the sunroof is playing up, It typically begins to close and right at the last second it stops and begins to retract back again. It's almost as if it is detecting excessive pressure as its shutting and deciding to open back up again. I've checked the tracks for any dirt/debris and it all looks good. I've also sprayed some silicone spray into the tracks and on the sunroof runners, however this still doesn't seem to help. Does anyone have any thoughts on what could be causing this issue? I'm going to contact a cupra garage to get them to look at it, but just wondered if anyone on here has had this kind of issue before. Many thanks.
  • Sad
Reactions: Syphon
Going to be purchasing a VZ3 myself when I've sorted a few other things and it's something that comes up a lot across multiple owners
Seems trying holding the lock button on the key can sometime work, but sounds like the modules are a bit cheap and need replacements - post back on here once garage have had a look and let us know how you got on....
Reactions: Tell
Yes will do, it's booked in for the end of Feb. I'll post back on here with the outcome...
Reactions: Tell
Garage told me that the entire sunroof needs replacing. There is apparently a defect (from manufacture) on one of the sunroof rails which is causing the sunroof motor to experience excess strain so it is retracting backwards again to avoid damaging the sunroof motor (safety feature). Entire roof interior & seats need removing in order to refit a new sunroof unit. Luckily all covered under manufacturer's warranty.
Reactions: Tell and trew
Rubbish - i have a 2023 who suddenly got the error where sunroof closes almost and then decides to open again, and that error def came after the OTA update (from v1940 to v1989). And that error (where it almost closes and reopens) have funny enough been repported many times the last couple of monts.
UPDATE: CUPRA Garage has completed the sunroof work under warranty. They removed the interior side trims, dropped the roof lining and completely replaced the panaramic sunroof unit with a brand new one. The sunroof works a treat now and they completed the warranty work superbly. They also installed the latest PV4 update to the car system which has fixed certain bugs and issues with regards to the infotainment system and flickering ambient lights. Very impressed with the service they have provided.
Which garage? It's always nice to know of a good one.
