Although I live in quite a large village, it’s in a semi-rural area with very few street lamps and within minutes I can be in the middle of the countryside driving on quite narrow roads with lots of twists and turns. My non-VAG car also has auto high beam and apart from when I first got the car, I’ve never used it; I always switch to main beam manually when I need it as the ‘logic’ programmed into the auto high beam functionality doesn’t match my requirements. In my car, it doesn’t activate at speeds below 20 mph and it switches from high to low beam when slowing down to speeds above to below 20 mph. It’s then that I often also need full beam immediately e.g.
- after negotiating tight bends on unfamiliar country roads
- to clearly see the edges of narrow roads and hazards such as pot holes
- to avoid the wildlife. There are lots of muntjac deer in my area that seem to appear from nowhere and can cause quite a lot of damage if you’re unfortunate enough to hit one. It doesn’t do the deer much good either.
On faster main roads, I’ve also found high beam can be quite slow to respond to auto-dip back to low beam when there’s oncoming traffic. I’ve been flashed a few times because I’ve dazzled the drivers of those oncoming vehicles.
In nearly 50 years of driving, my current car is the first one I’ve owned with auto high beam. I’d certainly not miss this feature if any future car I bought didn’t have it.
