What CUPRA Raval Model have ordered or do you own?
  • CUPRA Raval Origin 37kWh 115PS 5dr Auto
    Votes: 0 0.0%
  • CUPRA Raval V1 37kWh 135PS 5dr Auto
    Votes: 0 0.0%
  • CUPRA Raval V2 37kWh 135PS 5dr Auto
    Votes: 2 6.7%
  • CUPRA Raval V1 52kWh 210PS 5dr Auto
    Votes: 6 20.0%
  • CUPRA Raval V2 52kWh 210PS 5dr Auto
    Votes: 3 10.0%
  • CUPRA Raval V2 Launch Edition 52kWh 210PS 5dr Auto
    Votes: 11 36.7%
  • CUPRA Raval VZ 52kWh 225PS 5dr Auto
    Votes: 4 13.3%
  • CUPRA Raval VZ Extreme 52kWh 225PS 5dr Auto
    Votes: 4 13.3%
  • Total voters
    30
Yeah there is a lot of misinformation flying around.
Not sure we can spec the heat pump over here, its not on the configurator, or at least not for the VZ extreme.
Yea this is another big misconception people also have, thinking you have to use the configurator. The UK has heat pump option too but it's not available when you use the configurator (neither is it in Finland), you have to put an order through your local dealer. Pricing and options and such be found here: https://www.cupraofficial.co.uk/price-lists/cupra-raval
It's a £800 extra. (would have looked better if this was included by default but VAG group doesn't seem to be too fussed about heat pumps in general...)
Got ya....
Its actually £960 with the vat!
Maybe if it was nearer £600 I'd consider it but as the car will be mainly short trips and overnight cheap charging, I'm not sure its worth it, unless I'm missing something?
Got ya....
That's too much imo especially for UK where it's less useful than up here north. In Finland it costs 900€ incl VAT (~£772), I was a bit 50/50 or maybe 55/45 or so towards picking it in the end but if I was from the UK I wouldn't pay £960 for it (at 600~£650 I'd consider).
Purely some unscientific predictions based on some tests I've seen I wouldn't be suprised if during the winter months in UK you might gain up to 8~11% or so range and in Finland I predict up to around ~15% benefit during winter but autumn/spring maybe 3~5% benefits. Sure it will also perhaps heat up a little quicker and people tend to think it's a bit more "pleasing" feel to the cabin perhaps if going by other brands but doubt its a night and day difference there, just subtle nuance.
Reactions: Ju.
It's probably not possible for me to change anymore but cannot help but ponder whether I did the right decision or not as I'm such an extreme example of guy with a decision making anxiety, whether to pick the panoramic roof or not in this case, it's a 650€ with VAT included option here. Friends and family keeps telling me, nah don't pick it but I've never had experience of one myself, I just keep argumenting myself of cons vs pros but could never get to any concensus that would weigh heavier towards "no" or "yes".
Cons:
- Will let more sunshine in meaning to slightly warmer interior in summer or colder during winter. Especially I've read panoramic roofs can add a bit of a chilly feel coming through during particularly cold winter days. Sure it has a closeable sunshade but probably it won't fix these things fully though. AC will have to work slightly harder, so slightly worse range.
- A little bit more noise than with no sunroof.
- Since Cupra Raval has so much interior lighting (I have the optional package with the more advanced interior lighting) it would seem counter-intuitive to make the interior brighter for the lights to pop out less
Pros:
- Makes interior feel a bit bigger and spacious
- Gives a bit more "luxurious" feel, especially when you are able to close and open at will. (there's some added pleasureness to be able to so, a bit similar feeling for me when using Home Assistant and just pressing a button to turn on the AC from the dashboard)
- Possibly makes the exterior slightly nicer looking? (unsure)
This is is the thing I dislike with being able to spec your own, just too many things to think about, easier when you are given a car that's just been imported and it's either take it or leave it and then you take the option you are unsure about as it comes... 😅
@RPGWiZaRD - I agree with your friends and family; don’t pick it. As the saying goes; ‘what you’ve never had, you never miss’.
Another couple of ‘Cons’ to add to your list;
  • If you’re unfortunate enough to have a panoramic roof that creaks and rattles (some of them do), those creaks and rattles can be very difficult - if not impossible - to eliminate. That would drive me crazy and IMHO a creaking and rattling roof panel would certainly spoil the ownership experience.
  • Longer term, the roof panel drain pipes can also become blocked. If this happens, instead of water draining to the outside of the car, it can drain into the car’s interior.
I have had cars with a sunroof in the past - before the days of cars having air con. The last car I owned that had a sunroof was nearly 25 years ago. Have I ever missed not having one since then? Absolutely not.
Reactions: RPGWiZaRD
Thanks, this was the "push" I needed I think. I think the saying "what you've never had, you never miss" is a good one to apply here, is better for future in mind in case I'd have actually enjoyed the panoramic roof for whatever reason, I don't know what I'm missing out on and won't miss or need next time it's time for a new car either if the model doesn't happen to come with one.
Well I'll jump firmly on the other side of the argument tbh.
Each of my last 5 cars have had one and its the first thing on my wish list.
I sat in one in Gloucester Cupra that had the panroof and it does make the interior feel larger and brighter. Its a shame it doesnt open but that in itself makes it simpler and less prone to issues.
Each to there own
Yeah I ordered a VZ extreme in Plasma with the panroof.
I'm not in a rush as it isnt replacing anything, id just like to track its progress and I'm running out of videos to watch on youtube....watching all the auto dubbed ones now :ROFLMAO:
I have worked out why there are delays on our orders. They are giving cars to dummies! 😂
I was literally watching this one when you posted it haha. Besides the tests my attention was drawn to the 18" rims with the bright accents, first time I've seen those and I think it looks actually pretty nice with Fiord Blue. The other 18" ones that are similar but without the bright accents looks far far worse to me. But with VZ it's not even possible to pick those 18" ones eitherway. I like how the Fiord Blue looks in this video too, the more "greenish" tone the better, sometimes it looks more bleak blue'ish, sometimes more almost like a dark grey green and then it looks very nice. Guess I'll have to wait n see what it ends up like in real life haha. 🤣
At 1:07 the logo becomes a flying shuriken. 💀👀
Reactions: MarkHa
Nothing fancy but this should be the first Fiord Blue with midnight black roof posted as well as the first look of the "Pulse" entry level upholstery. I was long debating with myself whether to go midnight black roof with Fiord Blue or not as it was a 400€ extra here to do so but I'm kind of glad I didn't pick it with Fiord Blue as I'm not that much into it personally, I do think the black roof works better with Plasma paint though and with that option I wouldn't mind it.
Reactions: MarkHa
Exactly what I have on order, Fjord blue works well with the 18 Defier anthracite wheels and black roof is a no cost option in the UK and with the black A pillar and black strip on the C pillar gives the floating roof effect and breaks the colour up. The V2 Launch Edition I had worked better in Plasma with the copper wheels though.
Hi all just joined I have ordered a V2 LE in grey, had a Born for the last four years.
Had a message this week from the dealer to say it's at the port waiting to go on a ship
Same as me nearly. I have had a Born three years mine is the VZ Extreme and that’s is also at the port. We maybe neighbours!
Reactions: Pmac16
Me again like it when the black strip is very visible and it will stand less out when you pick midnight black roof. I think generally black roof works better for me with a more contrasting (bright) color (white, yellow, red etc) and I think Fiord Blue isn't strong enough of a contrasting color for the black roof. Even if it was a no cost option I'd be unsure which to pick, the 400€ difference settled it for me though. Both looks good so guess it's a positive problem to have haha. My Mazda 3 also have subtle black strips at the side of the roofline and such that I like.
Especially from the side I enjoy the look with the very visible black stripe (didn't find any good Fiord Blue examples so using Matte green):
Reactions: jezyg
I've just ordered a Raval V2 Launch Edition in Magnatech Grey with Copper trim on the wheels. We really wanted the car in Plasma but the dealer didn't have access to one. We also ummed and arrred about whether to go for the VZ as that comes with the sunroof but the value of the V2 Launch Edition swayed us. Looking forward to getting it in September but there is a nag in my head saying should have gone for the VZ....but my head ruled my heart. Very excited to get it.
I've just received an email saying my Raval order is now built and is in transit. Any ideas on how long to get to the UK port?
My dealer told me on Saturday and Cupra sent an e-mail today with the same message.
I'm expecting it to take about 3 weeks before it's available for collection.
Transport Route and Logistics
    • Port of Departure: Vehicles leave from the Port of Barcelona where Cupra (as part of the Volkswagen Group) stages factory-fresh exports.
    • Port of Arrival: Common destination ports in the UK for these volume shipments include Port Sheerness in Kent or Grimsby.
    • Delivery Timeline: The maritime leg of the journey usually takes about a week, followed by a few extra working days for customs processing, vehicle registration, and final road transport to dealerships.
Reactions: shearmr
There are a couple of RO-ROSs currently en route to Barcelona (in the med at the moment) will keep an eye on them to check when they change their destinations prior to setting off.
(Yes I am that sad😁)
Reactions: shearmr
Thank you 👍
This waiting kills me haha. My custom order VZ is estimated for production in week 41. Looks more and more like the first drive on Raval will happen with winter tyres.
BTW, a very small detail I just noticed and was slightly curious about as the Raval demo car reviews popped up how they pick the "accent" colors on the exterior as far as the stripes at the front and rear diffuser goes, if it's per color option (like Plasma gets automatically copper accents or Fiord Blue gets automatically black ones etc). Seems like it's VZ model that gets copper ones (I prefer that) unless picking the Extreme variant with the sulphur green and Endurance (or V1/V2) gets black ones. Seems like with the updated finnish site's configurator you can now also spec the basic VZ and updates the pictures as you pick the options, like my VZ with the default Rebel copper tyres and Fiord Blue paint shows copper accents there, they are black if I pick Endurance model etc. and it stays irrelevant of color option I choose.
Reactions: Superswede
I ordered an Iridescent Plasma VZ Extreme at the end of July, and I'm collecting in on Saturday. It was originally in black, but the wait for that was December. I prefered the plasma, but was taking the cheap paint option - the dealer offered to split the paint difference, if I took a September delivery!
Reactions: jezyg
