vicalva
83
7
Madrid
Hi everyone. Just wanted to share a small inconvenience I've encountered with my Raval V1 since I got it in July.
When I charge the battery up to 80% at home and then start the engine, I get a series of alerts on the dashboard about the ADAS: front assist, side assist, lane assist, park assist etc. The alerts say these systems are either failing or working with limitations.
If I turn the engine off and restart it, all the faults vanish from the dash, as if nothing had happened. More inportantly, the car drives normally and the ADAS seem to work fine.
I don't have this problem if I only charge up to 60%.
A friend of mine has the exact same thing with his Raval.
Cupra tells me to take the car to the dealership for inspection, but the dealership finds no error.
I'm very happy with the car overall, but find this slightly annoying. Anyone else with this issue and a possible solution?
I've had the same issue with front assist messages and a yellow triangle in the instrument display. I always charge to 80%.
I keep my car in a garage which means the front assist is usually triggered when I park and charge overnight. Once I back out and drive off, the message goes away. That was with the software version 6.0 as delivered. I completed an OTA update to 6.0.1 a couple of days ago and I haven't seen the problem since.
Reactions: vicalva
Thanks for that. Good to know the update took care of the ADAS failure false messages.
I tried to update to 6.0.1 version O.T.A. back in September, but the installation failed and I've got a permanent yellow triangle on the dash since, because of this. Unfortunately, the system won't let me try the update again.
I took the car to the dealership to clear the fault and have them to manually install the 6.0.1, but they couldn't do it to this day, they claim they depend on Cupra Tech department whom are not giving a response as yet. I have an open case with Cupra on this. Hopefully they'll sort it out soon.
