Oct 11, 2026
London SE9
Morning all
This topic may have been covered before i dont quite understand the on board psi boost if i accelerate harder ive got it to go up to 26.7psi surely this isnt correct for a stock car , dealer has assured n me its stock
The EA888 gen 3 from an S3 has charge pressures listed at 17.4psi (1.2bar) - so a stock 290 should be around this I would suggest.
Boost pressure can be read in two different ways - relative or absolute - how does your gauge read?
Though your 26.7psi seems to align with google for a remapped car!
Its just the on board psi so im sure this would be absolute
Reactions: nd-photo.nl
Its probably with ambient pressure included, so you need to subtract about 0.9 bar (13 psi). I remember seeing a high value there with my unmapped 280. To be honest I never used those gauges again after I added a separate boost gauge, which purely reads out boost pressure.
Yea i googled and the inbuilt one on screen is with ambient included
That looks like a nice bit of kit mate
I gave my some boot to the floor treatment earlier come up with 36.7 psi reading now i no you have to minus 14.7 or so thats 22psi is that stock readings im new to all of this always had old man cars lol
Yes as I mentioned in the other thread it measures boost pressure + atmospheric pressure (absolute pressure), at sea level atmospheric pressure is ~14.7 psi (or 1 bar). The stock map sensor is 3 bar so it can't read anything above 44psi, so yours is reading correctly. (y)
Stock boost pressure for 300ps S3 is 17.4psi - so your 22psi looks like it has a mild map to me.
Agreed, it definitely seems to have a mild map. I was just confirming that their screen and factory 3bar map are working and reading the data correctly, rather than being broken or glitched out. But yes, a true 22psi means that it must be tuned.
