Oct 27, 2026
Bonjour,
j'ai une Leon 5F FR 1.4 TSI 150ch de 2018 (phase 2), unité MST2 P0480T. Dans le menu "véhicule", l'option « rabattre les rétroviseurs à la fermeture » est cochée, mais le rabattement ne se fait qu'avec un appui long sur la clé ou sur le capteur de poignée. Quelqu'un a t-il réussi à le faire dès l'appui bref ? Avec quel outil, quel module et quel paramètre ?
Merci par avance.
Hello, I have a Leon 5F FR 1.4 TSI 150hp from 2018 (phase 2), unit MST2 P0480T. In the "vehicle" menu, the option "fold the mirrors when closing" is checked, but the folding is only done with a long press on the key or on the handle sensor. Did anyone manage to do it from the short press? With which tool, which module and which parameter? Thank you in advance.
@Hervé B you are better off posting in english if you want a response from the community.
Bonjour,
Merci par avance.
Following instructions are for OBD11.
Control units -->
Central Electrics (09) -->
Adaptation -->
Spiegelverstellung -->
Funk Spiegelanklappung Modus -->
change the setting from "by convenience operation via remote control key" to "by look command via remote control key"
Then write the change to the control unit.
Some of the following prerequisites may need to be met before performing this change:
- Security access code entered (OBD11 provides alternative codes on the control unit login screen)
- Bonnet and/or driver's door may need to be open
- Diagnostics mode may need to be set to "Development" or "EOL".
I can't exactly remember which ones were actually required while performing that change but you can find the proper setting by trial & error.
