Nov 6, 2026
Looking to get some wheels for my mk3 leon, anyone got any thoughts or some examples they could share?
Not a fan of the stock 16 inch alloys
Thought some pretorias would look good, also maybe canyons (from the caddy/passat alltrack/golf cross), or possibly just the design wheels that come on the FR trims.
There are hundreds of potential wheel options!
I used to use my old Audi B6 6 spoke avus alloys for winter wheels which were exactly the same size as the FR 17"
I would start with what size tyre you want - and then go from there?
Also if you go bigger wheel size - then the tyre to arch gap gets more noticeable so you may also think about lowering it a little as well?
Reactions: Mo_86
As @SuperV8 mentions, there are so many options. Do you want an OEM option or aftermarket? Which size do you want?
For some inspiration: I have 2 19" wheelsets for my ST. I would recommend not going over 18". Although 19" looks great (to me), the ride becomes a bit "crashy" even with DCC dampers.
OE Cupra wheels in black (stock springs + dampers), 235-35-19 tyres
AP1GczP2YnPBbG2yGEn4CBdkJ31cccoNSjGT9XNwoYbH6PWaoL8iaRl_PAQYS5F_sI2r7wQwO2fkBe5VHNj6TiYt4ws7kO2bnsntxxHx6muFRZM7v-2cp2kyr_Ms7ZSRaAje2u3-O7ti6fPBkzXFw4ul5ojx_w=w1920-h1281-s-no
AP1GczNLig3yDrPXhNrGmTHLJ2ZRV7Ooco6Gy0r5-6_9UaFKOb9fdwoYAZ_K7FLINaGW_sBX9MEEmxwTHAnRuW_9fyWGPXl1OP6jLity2AsdxBf-UBFhBxulRpTC61m5FD6wM_bMiWO7ci7zwpHpw1napcoN1Q=w1920-h1080-s-no
MM-06 wheels in bronze (stock springs + dampers), 235-35-19 tyres
AP1GczNhd1Uq89HZr88D_YFzgdq-BKYoIaVsdmFF63dZsCkdp3Z_pdtPzoguFUVJ4Kd_sFi3W3p4q39IvKtG8pTEP7AfwJBB6MhMZGvHQypR02zccx4Kql4FCEjeQPGRaOWTO0rxD5_9w4DVp40K-At3yFCzng=w1920-h1080-s-no
AP1GczNbxY8KU-Jzz3WBACBPQXYQZ835ON4oUyUbpRrhEycGXSxV0DKT1_UHBxm-TTcodi6w2lFBY35bnNyZS8CmLX62bQh6xB-7XG2wBLys2ArM3SCJ6c1AqXesm8ckI0zasxZCJ8pYMl8iUsoMGFBAYJzXnw=w1920-h1080-s-no
Reactions: SuperV8 and Mo_86
Two 18" alternatives from SEAT themselves. The bicolor diamond cut one was the best looking alloy wheel option for non-Cupra versions of Mk3 Leon in my opinion. The other one has also a full gloss black variant.
was thinking about 245/40r18 and lowering by 20-30mm not sure if 245 would be too wide for the arches or fit just right, i think the fr wheels are 225?
