I may be onto something here?...
I just did a few tests of the auto-lock system in conjunction with the trunk lid.
A couple of times it worked as it should, but on the final test when the trunk lid was the last thing to be closed, the car failed to lock itself. I'm not sure of the entire sequence, but it definitely failed to lock. I know I walked away while the lid was closing.
Would anyone else like to test the theory too?
Probably thought you were there still. The powered tailgate will be an adjunct to walk away locking. That can be a little temperamental least in the Ateca. May be dropping the tailgate then does a handover to check whether the keys are still present and that can get lost. It would not want to put a lock instruction in to all doors if the trunk was moving say. Might be deemed you haven't left yet. Might be some algorithm of how it passes control between systems and that one has a hole in it. Needs some budding youngster to do a flow diagram 😉. Keep the kids busy. Scientific experiment.
  • Haha
Reactions: trew
I did a small 'repeat test' yesterday afternoon and - just like a main dealer - I couldn't replicate the fault! Tried all sorts of combos of open/shut door sequences and the flippin' walk-away autolock worked every flippin' time!
...and that's why I don't trust it. It pretends to work all the time then, unexpectedly, one day you find your car's unlocked.
  • Haha
Reactions: Tell
Well the tailgate plays up with the odd foot wiggle but I expect you were pressing the button. I get excited if I find the second set of keys in the car with the door shut not locked. More excited if locked. It does allow that.
It does actually leave you locked out if the battery goes flat with you outside with the keys. You probably knew that. Had the condition when the battery gives up and you can't lock the car. Had the one where the battery goes flat and you can't get inside the locked car. Moral always keep a spare battery on you. Rotate one between the spare battery on you and the next unsealed one. A small zip bag is sufficient.
But either way I would not use walk away locking or unlocking. Encourages a lack of rigour locking the car and if it doesn't always work defeats the object.
Reactions: Seastormer and trew
Hi trew would you send me an email citing the fault with the kessy lock/unlock system. Has it been into the dealer? I have just rejected my car on the basis that the kessy system is not fit for purpose and lets me down on occasion. They want me to take it back to the dealer so they can hook it up and see if there is any fault at all because they haven't come across it, and as you know it's tempremental when it fails or doesn't
I would really appreciate it if there are any guys out there having locking/unlocking issues with the kessy system. They seem to deny that there's an issue. My Leon is just a month old and it's the second one with the same not locking when I walk away from it. Doesn't happen all the time that's why they claim not to be able to find it and won't accept my rejection without them being able to find the fault. So if this happens or has happened to you, please message me or put something on here that I can present to the dealer. Thanks
I know plenty of people who simply disabled the away/approach lock/unlock function because it is really unreliable. I (and obviously many others) hardly see this misbehavior as a solid reason to reject any car - unless this function is actually the main reason you bought this car.
I'm using the handle-touch lock/unlock function - the success rate of that is a lot higher I'd say. That's unless the handles are really dirty, or have some ice/snow deposits.
I think it's a gimmick myself. Its asking for trouble in areas of crime. Even if its working people can jump in the car. Only if you are very forgetful about locking the car it has a use. With Kessy easy enough to touch the stud / special area. Configure mirrors to turn in on lock. Job done. You hear the sound and can glance back to see the mirrors are in.
BTW I gave a tutorial to a Formentor driver on Friday in Lidl car park with the virtual pedal. They were wiggling their foot to no avail. I told them the exact procedure of foot under and step back to break the signal so it knows it's not opening on you. They didn't know that... not a lot do... @Syphon
Thanks for replying, it is the main reason for rejection because this is the 2nd Cupra I've bought from them, in just over a year, probably thinking like they were that it won't happen twice. I see that lots of peop;le have the same issue throughout Europe, I'm just interested in why they haven't done anything. On one forum someone complained as long as 2023, and now on the Born forum there are people complaining about the same issue... Now that is odd
I would imagine (as is the case with most systems in modern vehicles) that if the KESSY system is not 100% happy with the data it receives and how it interprets the situation, then it's failsafe reaction is to not lock the car. Better that than to lock when it's not supposed to and cause a potential lock-out scenario.
It's not a strong reason for rejection, especially given that there are the two easy alternatives of pressing the pad on the door or the key itself. I'm sure I won't be on my own here when I say that the majority of people will want to ensure that the vehicle is locked and won't put their entire trust in the vehicle out of pure diligence.
Regarding the virtual pedal mentioned above - so many people don't step back.
The "pedal" sensor under the bumper works in conjunction with the parking sensors to confirm you're not in the way of the tailgate. Fail to move or move far enough away and the system will (by default due to the unfulfilled prerequisites) not operate.
Are there similar proximity locking/unlocking problems known in other brands? My wife had a '20 Peugeot 2008 for a year and a half, I liked that car for some reasons, and disliked it for others. It had that feature, and we never experienced a problem with it. I believe there are manufacturers who could get that right.
Well it could always be coded in prior to Seat / Cupra bringing it out as an option. VWs had it long before it came to us. It does beg the question that it took a few years before it came to Seat / Cupra. I'd go with @James_R theory that it opts to do nothing if there is not a clear indication of what it should be doing. Originally a lot of people were locking their keys in the boot on VWs. The Kessy aeriel is suppose to pick up the signal that the keys were in the car. Evidently those that locked them in the boot it hadnt picked up the presence... generally its a good idea not to mess with the Kessy.
I have a non VWG vehicle, the keyless entry/exit system is brilliant but I do always lock the car via the fob when it's parked on my driveway, as the car picks the key up from my kitchen and gets a bit confused (door handles pop out ready to open, the vehicle eventually re-locks itself).
A few months ago we sold the first of the new small electric vehicles from VWG. It came with 1 x key and 1 x card. The customer's mobile phone was not compatible with the digital key system. They placed both the key and card in the boot then closed the tailgate. Have a guess what happened?
I stayed at work until 8:00pm gaining non destructive access to said vehicle so the customer could drive back home the following day.
  • Haha
Reactions: Momochi and Tell
Ah so it still does it :oops:. Generally not a good idea to put the keys in the boot. The VW people were putting theie jacket with keys in the pocket in the boot, sports kit with keys in the bag in boot etc... you need just a bit of discipline on where you keep the Kessy keys. Just keep them on your person. I never touch them except when I give them to the dealer or tyre place.
Reactions: James_R
Exactly that scenario 🤣
Reactions: Tell
Tried a few times when I parked at roadside to pop into a shop with the key fob on me, the car locked itself with my son in the car (with the alarm went off ) 🤣🤣
Now I need to leave the key fob with him everytime he was left alone.
No worry, he will be leaving home to start university life next summer, no more being locked when left unattended. 😅😅
  • Haha
Reactions: tracktoy and trew
Beware of the 90mins parking limit at Lidl carpark 🤣🤣
If its like the Ateca there is no way for the unfortunate person to get out. Locked Kessy by hand, complaints about being locked in. Silly me thinking about the shopping list.
2 hours round here but enough to walk to the GP.
Lidl carparks in East London mostly have limits of 60 or 90 mins, some even needing you to register with your shopping receipt to activate the free parking.
