Probably thought you were there still. The powered tailgate will be an adjunct to walk away locking. That can be a little temperamental least in the Ateca. May be dropping the tailgate then does a handover to check whether the keys are still present and that can get lost. It would not want to put a lock instruction in to all doors if the trunk was moving say. Might be deemed you haven't left yet. Might be some algorithm of how it passes control between systems and that one has a hole in it. Needs some budding youngster to do a flow diagramI may be onto something here?...
I just did a few tests of the auto-lock system in conjunction with the trunk lid.
A couple of times it worked as it should, but on the final test when the trunk lid was the last thing to be closed, the car failed to lock itself. I'm not sure of the entire sequence, but it definitely failed to lock. I know I walked away while the lid was closing.
Would anyone else like to test the theory too?
